Grafana v9.5.0-cloud.5 -
I have currently connnected my grafana instance to influxdb hosted in AWS cloud.
But i have my old data in my localhost influxsn instance and when i try to connect it there was an error like: post “http://127.0.0.1:8086/api/v2/query?org=LDO-test”: dial tcp 127.0.0.1:8086: connect: connection refused error reading buckets
When i connect same localhost influxdb to localhost grafana instance http://127.0.0.1:3000/. Its working with same token and same configuration, but with grafana cloud pro same source is not working,
What happened?
I would like to connect to my old data store in local hostinflux from grafana cloud. -
List of source IPs to add to your allowlist | Grafana Cloud documentation
