Looking for a grafana freelancer to get me started (json api's)
looking for somebody who can help me to get started with adding json api’s to my grafana, I tried it but :face_with_peeking_eye:
paid work off course
welcome to the :grafana: forum, @svanzuidam
what datasource plugin are you using to get the api data into grafana? Is it this one?
I tried that one yes but also another one.
Hi, I have written a short tutorial on how to use the SimpleJson data source. You might want to check it out if it is what you want.
Creating Dynamic Auto-Updated Time Series using Grafana | by Wei-Meng Lee | Mar, 2022 | Level Up Coding.
Thanks!
hi,
You can contact me on samant.rags@gmail.com with details.
Regards
Samant
Hi All,
Sorry for the silence, I was busy fixing it all :slight_smile: I actually got it all working, I now have connections to multiple endpoints, bol, amazon, zendesk, magento, shopify and my raspberry pi will autoload the browser and grafana
