Loki s3 sub folder
Does Loki support subpath/subfolder for s3 bucket to store logs like tempo support for traces?
I don’t believe so.
Is subfolder supported now ?
and if not , do we need 3 buckets for chunks, ruler, admin. Or can we have one for all ?
I am planning to deploy simple scalable edition.
I dont think subfolder is supported, nor do I think it should or it’s necessary.
You need one S3 bucket for index and chunks, and one for ruler if you are using clustered ruler. There is no such thing as admin.
Then what does this official documentation says is admin ? What’s that for ?
It’s not part of OSS Loki, see loki/docs/sources/setup/install/helm/deployment-guides/azure.md at c084144d29b97ee027a442c3a8477ed621d3855b · grafana/loki · GitHub
