Loki error: Failed to call resource
Hi all,
I am using Grafana(v9.5.1), Loki(helm-loki-5.6.1) and sub path named as loki for storing log inside s3.
This is my configuration:
 # Required policy for s3 bucket to store object
        sa.add_to_principal_policy(iam.PolicyStatement(
            actions=[
                "s3:PutObject",
                "s3:GetObject",
                "s3:DeleteObject",
                "s3:ListBucket"
            resources=[
                f"arn:aws:s3:::log_bucket/*",
            effect=iam.Effect.ALLOW
        chart_specs = [
                "name": "loki",
                "chart": {
                    "repository": "https://grafana.github.io/helm-charts",
                    "name": "loki",
                    "version": "5.6.1"
                "values": {
                    "loki": {
                        "limits_config": {
                            "enforce_metric_name": False,
                            "reject_old_samples": True
                        "commonConfig": {
                            "replication_factor": 1,
                        "server": {
                            "grpc_server_max_recv_msg_size": 104857600,
                            "grpc_server_max_send_msg_size": 104857600,
                        "storage": {
                            "type": 's3',
                            "s3": {
                                "region": "us-east-2",
                                "s3ForcePathStyle": False,
                                "insecure": False,
                                "sse_encryption": True,
                            "bucketNames": {
                                "chunks": "log_bucket/loki/",
                                "ruler": "log_bucket/loki/",
                                "admin": "log_bucket/loki/"
                        "auth_enabled": False,
I am trying to store logs in the subpath, but suddenly I cannot access them from loki.
I am getting this error: Failed to call resource
After redeployment it worked but lateer same issue I faced.
Please help if configuration I am missing
