I’m using the loki-distributed Helm chart to deploy Loki in distributed mode:
I actually have my own chart of charts deploying Loki along with some other dependencies but this is a snippet from my Helm chart showing the chart repo and chart I’m using:
dependencies:
- name: loki-distributed
version: 0.42.0
repository: https://grafana.github.io/helm-charts
alias: loki
My values.yaml looks like this:
loki:
ingestor:
replicas: 1
persistence:
# -- Enable creating PVCs which is required when using boltdb-shipper
enabled: true
# -- Size of persistent disk
# -- Storage class to be used.
# If defined, storageClassName: <storageClass>.
# If set to "-", storageClassName: "", which disables dynamic provisioning.
# If empty or set to null, no storageClassName spec is
# set, choosing the default provisioner (gp2 on AWS, standard on GKE, AWS, and OpenStack).
storageClass: null
distributor:
replicas: 1
querier:
replicas: 1
ruler:
enabled: false
replicas: 1
indexGateway:
enabled: true
replicas: 1
persistence:
enabled: true
storageClass: null
queryFrontend:
replicas: 1
gateway:
replicas: 1
compactor:
enabled: true
persistence:
# -- Enable creating PVCs for the compactor
enabled: false
storageClass: null
serviceAccount:
create: true
My intention is to use boltdb-shipper for local storage as I don’t want to run my storage on Azure, AWS, Google, etc. and from reading the Single Store Loki (boltdb-shipper index type) guide it seems to recommend using the Index Gateway to cut down on use of persistent disk. Hence, I enabled the indexGateway:
indexGateway:
enabled: true
Unfortunately, when I deploy, my compactor, distributor, querier, and query-frontend pods all fail upon startup with this exact same error:
failed parsing config: /etc/loki/config/config.yaml: yaml: unmarshal errors:
line 51: field index_gateway_client not found in type storage.Config
These deployments all seem to be reading /etc/loki/config/config.yaml from the same ConfigMap: obs-loki in my case (from kubectl get deployment obs-loki-query-frontend -o yaml):
volumes:
- configMap:
defaultMode: 420
So I took a peek at that ConfigMap and it seems fine to me… I can see the index_gateway_client field there under storage_config so I am a bit perplexed:
apiVersion: v1
data:
config.yaml: |
auth_enabled: false
server:
http_listen_port: 3100
distributor:
ring:
kvstore:
store: memberlist
memberlist:
join_members:
- obs-loki-memberlist
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 1
chunk_idle_period: 30m
chunk_block_size: 262144
chunk_encoding: snappy
chunk_retain_period: 1m
max_transfer_retries: 0
wal:
dir: /var/loki/wal
limits_config:
enforce_metric_name: false
reject_old_samples: true
max_cache_freshness_per_query: 10m
schema_config:
configs:
index:
period: 24h
prefix: loki_index_
object_store: filesystem
schema: v11
store: boltdb-shipper
storage_config:
boltdb_shipper:
active_index_directory: /var/loki/index
cache_location: /var/loki/cache
cache_ttl: 168h
shared_store: filesystem
filesystem:
directory: /var/loki/chunks
index_gateway_client:
server_address: dns:///obs-loki-index-gateway:9095
chunk_store_config:
max_look_back_period: 0s
table_manager:
retention_deletes_enabled: false
retention_period: 0s
query_range:
align_queries_with_step: true
max_retries: 5
split_queries_by_interval: 15m
cache_results: true
results_cache:
cache:
enable_fifocache: true
fifocache:
max_size_items: 1024
validity: 24h
frontend_worker:
frontend_address: obs-loki-query-frontend:9095
frontend:
log_queries_longer_than: 5s
compress_responses: true
tail_proxy_url: http://obs-loki-querier:3100
compactor:
ruler:
storage:
type: local
local:
directory: /etc/loki/rules
ring:
kvstore:
store: memberlist
rule_path: /tmp/loki/scratch
alertmanager_url: https://alertmanager.xx
external_url: https://alertmanager.xx
kind: ConfigMap
metadata:
annotations:
meta.helm.sh/release-name: obs
meta.helm.sh/release-namespace: obs
creationTimestamp: "2022-01-27T17:26:39Z"
labels:
app.kubernetes.io/instance: obs
app.kubernetes.io/managed-by: Helm
app.kubernetes.io/name: loki
app.kubernetes.io/version: 2.4.2
helm.sh/chart: loki-0.42.0
namespace: obs
resourceVersion: "1393458"
uid: 919c4e28-bd5d-4f18-af0b-17653d58c505
Is there something wrong with the Helm chart or do I just have some value set incorrectly?
