I am trying to install the loki-distributed chart, using S3 for storage. I have deployed the exact same values to 2 other environments, one using Ceph and one using Minio. However, I am getting the following errors after deploying:
failed parsing config: /etc/loki/config/config.yaml: yaml: unmarshal errors: │
│ line 3: field max_look_back_period not found in type config.ChunkStoreConfig │
│ line 7: field shared_store not found in type compactor.Config │
│ line 29: field max_transfer_retries not found in type ingester.Config │
│ line 36: field enforce_metric_name not found in type validation.plain │
│ line 82: field shared_store not found in type boltdb.IndexCfg
These are the relevant Values.yaml:
storage_config:
boltdb_shipper:
active_index_directory: /var/loki/index
cache_location: /var/loki/cache
cache_ttl: 168h
shared_store: filesystem
filesystem:
directory: /var/loki/chunks
aws:
endpoint: "s3.us-gov-west-1.amazonaws.com"
region: "us-gov-west-1"
bucketnames: my-bucket/dir1/dir2
s3forcepathstyle: true
insecure: true
I have confirmed that the pods are mounting the corect ConfigMap, and the ConfigMap is structured according to the docs so i am not sure what I am doing wrong.
What does your index configuration look like?
I have not configured that, I did not have to in order to get loki running with the default values on the other 3 environments I currently have that all Mimir running. Not sure why that would prevent the yaml from being able to be marshaled into a struct.
Can you share your entire Loki configuration? You need at least one index configuration I believe.
Sure, As mentioned I am only overriding a few of the default values. By default it will configure one index:
schemaConfig:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: loki_index_
period: 24h
Overrides:
global:
image:
registry: &imageRegistry "localregistry:5000"
dnsService: "rke2-coredns-rke2-coredns"
- set tags for all images
- storageConfig:
storageConfig:
tsdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/index_cache
cache_ttl: 24h
# -- Uncomment to configure each storage individually# azure: {}
# gcs: {}
aws:
bucketnames: my-bucket/subdir1/subdir2
insecure: true
Here is the ConfigMap:
apiVersion: v1
data:
config.yaml: |
auth_enabled: false
chunk_store_config:
max_look_back_period: 0s
common:
compactor_address: http://loki-loki-distributed-compactor:3100
compactor:
working_directory: /var/loki/compactor
distributor:
ring:
kvstore:
store: memberlist
frontend:
compress_responses: true
log_queries_longer_than: 5s
tail_proxy_url: http://loki-loki-distributed-querier:3100
frontend_worker:
frontend_address: loki-loki-distributed-query-frontend-headless:9095
ingester:
chunk_block_size: 262144
chunk_encoding: snappy
chunk_idle_period: 30m
chunk_retain_period: 1m
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 1
max_transfer_retries: 0
wal:
dir: /var/loki/wal
ingester_client:
grpc_client_config:
grpc_compression: gzip
limits_config:
enforce_metric_name: false
max_cache_freshness_per_query: 10m
reject_old_samples: true
split_queries_by_interval: 15m
memberlist:
join_members:
- loki-loki-distributed-memberlist
query_range:
align_queries_with_step: true
cache_results: true
max_retries: 5
results_cache:
cache:
embedded_cache:
enabled: true
ttl: 24h
ruler:
alertmanager_url: https://alertmanager.xx
external_url: https://alertmanager.xx
ring:
kvstore:
store: memberlist
rule_path: /tmp/loki/scratch
storage:
local:
directory: /etc/loki/rules
type: local
runtime_config:
file: /var/loki-distributed-runtime/runtime.yaml
schema_config:
configs:
index:
period: 24h
prefix: loki_index_
schema: v11
server:
http_listen_port: 3100
storage_config:
aws:
bucketnames: machina-artifacts/management-prod/loki-logs
endpoint: s3.us-gov-west-1.amazonaws.com
insecure: true
region: us-gov-west-1
tsdb_shipper:
cache_ttl: 24h
table_manager:
retention_deletes_enabled: false
retention_period: 0s
kind: ConfigMap
metadata:
annotations:
meta.helm.sh/release-name: loki
meta.helm.sh/release-namespace: monitoring
creationTimestamp: "2024-11-08T13:33:45Z"
labels:
app.kubernetes.io/instance: loki
app.kubernetes.io/managed-by: Helm
app.kubernetes.io/name: loki-distributed
app.kubernetes.io/version: 2.9.10
helm.sh/chart: loki-distributed-0.79.4
resourceVersion: "13257165"
uid: 204c50e3-0ad9-4c2d-af33-951b9080206a
IMHO you are using old configs, which are not available in newer Loki version. E. g. chunk_store_config doesn’t have max_look_back_period
