Override helm config with custom loki.config doesnt work
Hi Loki,
I am trying to override configmap.yaml in loki helm chart 4.6.0 file which controls the storage option using values.yaml file, but have been unsuccessfull till now. Here is what my values.yaml file looks like. I have made sure i am providing a string since if we try to override the config we get following error.
Error: execution error at (loki/charts/loki/templates/validate.yaml:2:4): Top level ‘config’ is not allowed. Most common configuration sections are exposed under the loki section. If you need to override the whole config, provide the configuration as a string that can contain template expressions under loki.config. Alternatively, you can provide the configuration as an external secret.
values.yaml
loki:
  config: |
    auth_enabled: true
    common:
      compactor_address: loki-read
      path_prefix: /var/loki
      replication_factor: 3
      storage:
        s3:
          bucketnames: dpoe-1233-usw2-s3bucket
          region: us-west-2
          role_arn: arn:aws:iam::1233:role/dpoe-1233-usw2-s3bucket
          s3forcepathstyle: true
    limits_config:
      enforce_metric_name: false
      max_cache_freshness_per_query: 10m
      reject_old_samples: true
      split_queries_by_interval: 15m
    memberlist:
      join_members:
        - loki-memberlist
    query_range:
      align_queries_with_step: true
    runtime_config:
      file: /etc/loki/runtime-config/runtime-config.yaml
    schema_config:
      configs:
          index:
            period: 24h
            prefix: loki_index_
          object_store: s3
          schema: v12
          store: boltdb-shipper
    server:
      grpc_listen_port: 9095
      http_listen_port: 3100
    storage_config:
      s3:
        region: us-west-2
        role_arn: arn:aws:iam::1233:role/s3bucket
    table_manager:
      retention_deletes_enabled: false
      retention_period: 0
and using this command to template it
helm template charts/loki -f charts/loki/values.yaml --output-dir rendered/loki --debug \
Doing the above i dont get any errors but my changes arent applied to configmap.yaml and deployment doesnt update the storage option. At this time it will be helpful if i can know the ways of overriding the config file somehow.
