Loki retention overrides in helm not working
Hi, im trying to get Loki retention overrides to work
Global retention timings seems to be working, but not the override.
I´m running loki in fully distributed mode, and with helm version 6.19.0, with this configuration
The tenant i´m trying to override the retention for is named “team_x_logs”
From what i can see, the configmap is created and mounted to the correct path on the compactor pod, but the logs are stored even after the 24h that i have defined.
Any help would be appreciated
loki:
  compactor:
    working_directory: /var/loki/data/compactor
    compaction_interval: 10m
    retention_enabled: true
    retention_delete_delay: 2h
    retention_delete_worker_count: 150
    delete_request_store: s3
  limits_config:
    retention_period: 200h
    per_tenant_override_config: /etc/loki/config/override/loki-tenant-override-rules.yaml
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  ingester:
    chunk_encoding: snappy
  tracing:
    enabled: true
  annotations:
    kyverno.io/inject-cacerts: enabled
  querier:
    max_concurrent: 3
  storage:
    filesystem: null
    type: s3
    s3:
      endpoint: "${LOKI_S3_ENDPOINT}"
      accessKeyId: "${LOKI_S3_ACCESS_KEY_ID}"
      secretAccessKey: "${LOKI_S3_SECRET_ACCESS_KEY}"
      s3ForcePathStyle: false
    bucketNames:
      chunks: "${BUCKET_CHUNK}"
      ruler: "${BUCKET_RULER}"
  auth_enabled: true
  analytics:
    reporting_enabled: false
    usage_stats_url: ""
usage_stats:
  enabled: false
gateway:
  replicas: 1
  basicAuth:
    enabled: true
    existingSecret: basic-auth
deploymentMode: Distributed
ingester:
  replicas: 3
  extraArgs:
    - "-config.expand-env=true"
  extraEnv:
    - name: LOKI_S3_ENDPOINT
      valueFrom:
        secretKeyRef:
          key: LOKI_S3_ENDPOINT
    - name: LOKI_S3_ACCESS_KEY_ID
      valueFrom:
        secretKeyRef:
          key: LOKI_S3_ACCESS_KEY_ID
    - name: LOKI_S3_SECRET_ACCESS_KEY
      valueFrom:
        secretKeyRef:
          key: LOKI_S3_SECRET_ACCESS_KEY
    - name: BUCKET_CHUNK
      valueFrom:
        secretKeyRef:
          key: BUCKET_CHUNK
    - name: BUCKET_RULER
      valueFrom:
        secretKeyRef:
          key: BUCKET_RULER
querier:
  replicas: 3
  maxUnavailable: 2
  extraArgs:
  extraEnv:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
          key: BUCKET_CHUNK
      valueFrom:
        secretKeyRef:
          key: BUCKET_RULER
queryFrontend:
  replicas: 2
  maxUnavailable: 1
queryScheduler:
  replicas: 2
distributor:
  replicas: 3
  maxUnavailable: 2
compactor:
  replicas: 1
  extraEnv:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
          key: BUCKET_CHUNK
      valueFrom:
        secretKeyRef:
          key: BUCKET_RULER
  extraVolumes:
    - name: override-rules
      configMap:
  extraVolumeMounts:
      mountPath: /etc/loki/config/override/
indexGateway:
  replicas: 2
  maxUnavailable: 1
  extraArgs:
  extraEnv:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
          key: BUCKET_CHUNK
      valueFrom:
        secretKeyRef:
          key: BUCKET_RULER
chunksCache:
  enabled: true
resultsCache:
  enabled: true
# optional experimental components
bloomPlanner:
  replicas: 0
bloomBuilder:
  replicas: 0
bloomGateway:
  replicas: 0
lokiCanary:
  enabled: false
test:
  enabled: false
bloomPlanner:
  replicas: 0
bloomBuilder:
  replicas: 0
bloomGateway:
  replicas: 0
# Zero out replica counts of other deployment modes
backend:
  replicas: 0
read:
  replicas: 0
write:
  replicas: 0
singleBinary:
  replicas: 0
minio:
  enabled: false
memcachedExporter:
  enabled: true
  resources:
    requests: {}
    limits: {}
extraObjects:
- apiVersion: v1
  kind: ConfigMap
  metadata:
  data:
    loki-tenant-override-rules.yaml: |-
      overrides:
        "team_x_logs":
          retention_period: 24h
          - selector: '{os="linux"}'
            priority: 1
            period: 24h
What does /etc/loki/config/override/loki-tenant-override-rules.yaml look like?
It looks like my whole configuration was cut in the middle
Anyway, it looks like this
overrides:
  "team_x_logs":
      priority: 1
      period: 24h
That looks wrong to me. Assuming:
  • team_x_logs is the tenant that you are trying to override configurations in.
  • os="linux" is the label filter for the logs.
Try this (all logs under tenant team_x_logs are set to 24h retention):
overrides:
  "team_x_logs":
If you just want os=linux logs to be overridden, try:
overrides:
  "team_x_logs":
    retention_stream:
        priority: 1
        period: 24h
Thanks, i will try removing the retention_stream part from the configuration, and see if the retention overrides works as intended after that
I have tried the configuration for a while, but i am still unable to get retention overrides to work, and all logs only get stored according to global retention periods.
This is my current configuration that i´m running, i have double checked the spelling of the tenant name.
Is there some way to test that the override configuration file is read correctly?
loki:
  podAnnotations:
  compactor:
  limits_config:
    retention_period: 30h
    max_streams_per_user: 5000000
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  ingester:
  commonConfig:
    ring:
      kvstore:
        store: memberlist
  tracing:
    enabled: false
  annotations:
  querier:
    max_concurrent: 4
  storage:
    type: s3
    s3:
    bucketNames:
      chunks: loki-chunk-dev3
      ruler: loki-ruler-dev
      admin: loki-admin-dev
  podSecurityContext:
    fsGroup: 101
    runAsGroup: 101
    runAsNonRoot: true
    runAsUser: 101
    seccompProfile:
      type: RuntimeDefault
  containerSecurityContext:
    capabilities:
      drop:
        - ALL
    allowPrivilegeEscalation: false
  auth_enabled: true
  analytics:
    usage_stats_url: ""
usage_stats:
  enabled: false
gateway:
  replicas: 2
  basicAuth:
    enabled: true
  podSecurityContext:
    fsGroup: 101
    runAsGroup: 101
    runAsNonRoot: true
    runAsUser: 101
    seccompProfile:
    capabilities:
      drop:
        - ALL
ingester:
  replicas: 6
  extraArgs:
  extraEnv:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
querier:
  replicas: 3
  maxUnavailable: 2
  extraArgs:
  extraEnv:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
queryFrontend:
  replicas: 2
  maxUnavailable: 1
queryScheduler:
  replicas: 2
distributor:
  replicas: 3
  maxUnavailable: 2
compactor:
  replicas: 1
  persistence:
    enabled: true
  extraArgs:
  extraEnv:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
  extraVolumes:
      configMap:
  extraVolumeMounts:
indexGateway:
  replicas: 2
  maxUnavailable: 1
  extraArgs:
  extraEnv:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
chunksCache:
  enabled: true
  allocatedMemory: 3012
resultsCache:
  enabled: true
  allocatedMemory: 1012
bloomPlanner:
  replicas: 0
bloomBuilder:
  replicas: 0
bloomGateway:
  replicas: 0
lokiCanary:
  enabled: false
test:
  enabled: false
bloomPlanner:
  replicas: 0
bloomBuilder:
  replicas: 0
bloomGateway:
  replicas: 0
backend:
  replicas: 0
read:
  replicas: 0
write:
  replicas: 0
singleBinary:
  replicas: 0
minio:
  enabled: false
memcached:
  podSecurityContext:
    fsGroup: 101
    runAsGroup: 101
    runAsNonRoot: true
    runAsUser: 101
    seccompProfile:
    capabilities:
      drop: [ALL]
memcachedExporter:
  enabled: true
  resources:
    requests: {}
    limits: {}
    capabilities:
      drop: [ALL]
sidecar:
  securityContext:
    capabilities:
      drop:
        - ALL
rbac:
  pspEnabled: false
  sccEnabled: false
  pspAnnotations:
  namespaced: true
extraObjects:
- apiVersion: v1
  kind: ConfigMap
  metadata:
  data:
      overrides:
        "team_x_logs":
Think i found out the answer, i had added the retention override config to “per_tenant_override_config:”, when i switched to using “runtimeConfig:” instead, it started working.
Used latest version (as of now), loki helm 6.30 and worked with below way.
    runtimeConfig:
        overrides:
            tenant_1:
                retention_stream:
                  - KEY: VALUE
                  - KEY: VALUE
            tenant_2:
                retention_stream:
                  - KEY: VALUE
