Retention for different tenants not working in SimpleScalable mode
Hello everyone,
We’ve installed Loki in SimpleScalable mode connected to a MinIO instance onprem, right now we’re trying to implement data renention having multiple tenants activated.
First, we’ve made the configmap and it’s like this:
extraObjects:
 - apiVersion: v1
   kind: ConfigMap
   metadata:
     labels:
       app.kubernetes.io/name: loki
   data:
     loki-tenant-overrides-rules.yaml: |
       overrides:
         "tenant1":
           retention_period: 60d
           retention_stream:
             - selector: '{namespace="prod"}'
               priority: 2
               period: 30d
             - selector: '{container="loki"}'
               priority: 1
               period: 15d
         "tenant2":
           retention_period: 24h
           retention_stream:
               priority: 1
               period: 30d
         "tenant3":
           retention_period: 72h
           retention_stream:
             - selector: '{k8s.cluster.name="K8S-PROD"}'
               priority: 1
               period: 24h
         "tenant4":
           retention_stream:
               priority: 1
               period: 30d
Then, we’ve enabled retention like this:
loki:
  compactor:
    working_directory: /var/loki/compactor
    compaction_interval: 10m
    retention_enabled: true
    retention_delete_delay: 2h
    retention_delete_worker_count: 150
    delete_request_store: s3
  extraVolumes:
    - name: loki-tenant-overrides-rules
      configMap:
        items:
          - key: loki-tenant-overrides-rules.yaml
            path: loki-tenant-overrides-rules.yaml
        defaultMode: 420
  extraVolumeMounts:
      mountPath: /etc/loki/config/override
  limits_config:
    retention_period: 180d
    per_tenant_override_config: /etc/loki/config/override/loki-tenant-overrides-rules.yaml
ExtraVolumes and extraVolumeMounts is inserted inside Backend, Read and Write blocks as well like this:
backend:
  extraVolumes:
      configMap:
        items:
        defaultMode: 420
  extraVolumeMounts:
But currently retention is not working at all, and in the logs of the pod for loki-backend the only references to retentions are these logs:
Using Grafana with the Loki datasource we can still see older data.
Any tips or informations about this issue?
Thanks in advance!
Additional info, i tried to change the global retention to 3d, and now i can see these new logs:
level=info ts=2025-01-29T14:41:04.68898398Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161664675398685
level=info ts=2025-01-29T14:41:04.841865717Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161664830459215
level=info ts=2025-01-29T14:41:04.996596267Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161664982151030
level=info ts=2025-01-29T14:41:05.151796956Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161665137797613
level=info ts=2025-01-29T14:41:05.29193463Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161665276436901
level=info ts=2025-01-29T14:41:05.443950069Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161665431913435
level=info ts=2025-01-29T14:41:05.598116587Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161665585073313
level=info ts=2025-01-29T14:41:05.745340614Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161665727416898
level=info ts=2025-01-29T14:41:05.889544376Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161665876698696
level=info ts=2025-01-29T14:41:06.035831718Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161666024056538
level=info ts=2025-01-29T14:41:06.166878941Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161666153997601
level=info ts=2025-01-29T14:41:06.284638672Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161666272582873
level=info ts=2025-01-29T14:41:06.385079794Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738161666374405219
level=info ts=2025-01-29T14:56:06.422398997Z caller=expiration.go:78 msg="overall smallest retention period 1737903366.422, default smallest retention period 1737903366.422"
level=info ts=2025-01-29T14:56:06.524920866Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738162566520269991
level=info ts=2025-01-29T14:56:06.561257291Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738162566556003795
level=info ts=2025-01-29T15:11:06.422457051Z caller=expiration.go:78 msg="overall smallest retention period 1737904266.422, default smallest retention period 1737904266.422"
level=info ts=2025-01-29T15:11:06.532736938Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738163466526734583
level=info ts=2025-01-29T15:11:06.571724736Z caller=marker.go:77 msg="mark file created" file=/var/loki/compactor/retention/s3_2024-10-01/markers/1738163466565493428
From what i gatherered, this log indicates that Loki’s compactor component is processing retention periods. The “overall smallest retention period” and “default smallest retention period” are both set to 1737903366.422 seconds (approximately 55 years) so something is wrong.
I’m no expert on this, but I think it’s more significant that 1737903366 is the
epoch timestamp for Sun Jan 26 14:56:06 GMT 2025
Antony.
Thanks for the info Antony, checking today we see that the global retention is working, then it’s a confirmation that the per tenant one sadly is not.
Can you confirm the override configuration is actually mounted in your backend container?
If i check the pods for backend i can see the following:
 volumeMounts:
        - mountPath: /etc/loki/config
        - mountPath: /etc/loki/runtime-config
        - mountPath: /tmp
        - mountPath: /var/loki
        - mountPath: /rules
        - mountPath: /etc/loki/config/override
        - mountPath: /var/run/secrets/kubernetes.io/serviceaccount
          readOnly: true
  volumes:
    - name: data
      persistentVolumeClaim:
        claimName: data-loki-backend-0
    - emptyDir: {}
    - configMap:
        defaultMode: 420
        items:
          - key: config.yaml
            path: config.yaml
    - configMap:
        defaultMode: 420
    - emptyDir: {}
    - configMap:
        defaultMode: 420
        items:
Thanks!
No, I meant actually check the container.
Sorry, my bad.
Yes if i go into the contaier i can see the file:
And the content is correct:
/etc/loki/config/override $ cat loki-tenant-overrides-rules.yaml
overrides:
  "tenant1:
    retention_period: 48h
  "tenant2":
  "tenant3":
    retention_stream:
        priority: 1
        period: 24h
  "tenant4":
The values are different from yesterday because i’m trying things in the meantime :slight_smile:
Interesting. I don’t see anything obviously wrong. Are you running Loki in simple scalable mode, or micro service mode? Can you also share your entire Loki configuration, please?
Hi, i’m running Loki in Simple Scalable, i’m handling the migration from ELK stack to Grafana + MinIO / Loki stack with OpenTelemetry.
Do you think the issue could be with Simple Scalable? When we started we were using Microservice mode, but then we’ve been told to use Simple Scalable so we switched to that.
Here’s the entire yaml configuration:
global:
  dnsService: "rke2-coredns-rke2-coredns"
extraObjects:
 - apiVersion: v1
   kind: ConfigMap
   metadata:
     labels:
   data:
       overrides:
         "tenant1":
         "tenant2":
         "tenant3":
           retention_stream:
               priority: 1
               period: 24h
         "tenant4":
memcached:
  containerSecurityContext:
    seccompProfile:
      type: RuntimeDefault
memcachedExporter:
    seccompProfile:
## disable canary
test:
  enabled: false
lokiCanary:
  enabled: false
ruler:
  enabled: false
loki:
  persistence:
    enabled: true
    storageClassName: "standard"
    accessModes:
      - ReadWriteOnce
    annotations: {}
  compactor:
  extraVolumes:
      configMap:
        items:
        defaultMode: 420
  extraVolumeMounts:
  distributor:
    otlp_config:
      default_resource_attributes_as_index_labels:
        - "application.environment"
        - "application.name"
        - "application.component"
        - "server.hostname"
        - "log.file.name"
        - "k8s.cluster.name"
        - "k8s.container.name"
        - "k8s.cronjob.name"
        - "k8s.job.name"
        - "k8s.namespace.name"
        - "k8s.node.name"
        - "k8s.pod.name"
  auth_enabled: true
  revisionHistoryLimit: 1
  analytics: #disable messages to stats.grafana.com
    reporting_enabled: false
  limits_config:
    retention_period: 3d
    discover_log_levels: false
    ingestion_rate_mb: 32
    ingestion_burst_size_mb: 64
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  ingester:
    chunk_encoding: snappy
  tracing:
    enabled: false
  querier:
    max_concurrent: 16
  storage:
    s3:
      endpoint: http://minio.loki:80
      accessKeyId: ${StorageaccessKeyId}
      secretAccessKey: ${StoragesecretAccessKey}
      s3ForcePathStyle: true
      insecure: true
      http_config:
        insecure_skip_verify: true
    bucketNames:
        chunks: "chunks"
        ruler: "ruler"
        admin: "admin"
    runAsUser: 1000
    runAsGroup: 1000
    runAsNonRoot: true
    readOnlyRootFilesystem: true
    capabilities:
      drop:
        - ALL
    allowPrivilegeEscalation: false
    seccompProfile:
gateway:
    runAsUser: 1000
    runAsGroup: 1000
    runAsNonRoot: true
    capabilities:
      drop:
        - ALL
    seccompProfile:
  ingress:
    enabled: false
  basicAuth:
    enabled: true
    username: ${basicAuthUsername}
    password: ${basicAuthPassword}
deploymentMode: SimpleScalable
ingester:
  replicas: 0
querier:
  replicas: 0
queryFrontend:
  replicas: 0
queryScheduler:
  replicas: 0
distributor:
  replicas: 0
compactor:
  replicas: 0
indexGateway:
  replicas: 0
bloomPlanner:
  replicas: 0
bloomBuilder:
  replicas: 0
bloomGateway:
  replicas: 0
minio:
  enabled: false
sidecar:
  securityContext:
    runAsUser: 1000
    runAsGroup: 1000
    runAsNonRoot: true
    capabilities:
      drop:
        - ALL
    seccompProfile:
backend:
  extraVolumes:
      configMap:
        items:
        defaultMode: 420
  extraVolumeMounts:
  limits_config:
  replicas: 3
  autoscaling:
    # -- Enable autoscaling for the backend.
    enabled: false
    # -- Minimum autoscaling replicas for the backend.
    minReplicas: 1
    # -- Maximum autoscaling replicas for the backend.
    maxReplicas: 3
  extraEnv:
    - name: StorageaccessKeyId
      valueFrom:
        secretKeyRef:
          key: StorageaccessKeyId
    - name: StoragesecretAccessKey
      valueFrom:
        secretKeyRef:
          key: StoragesecretAccessKey
  extraArgs:
    - "-config.expand-env=true"
  persistence:
    volumeClaimsEnabled: true
    storageClass: "nfs-client"
    runAsUser: 1000
    runAsGroup: 1000
    runAsNonRoot: true
    capabilities:
      drop:
        - ALL
    seccompProfile:
read:
  extraVolumes:
      configMap:
        items:
        defaultMode: 420
  extraVolumeMounts:
  limits_config:
  replicas: 3
  autoscaling:
    enabled: false
    # -- Minimum autoscaling replicas for the read
    minReplicas: 1
    # -- Maximum autoscaling replicas for the read
    maxReplicas: 3
  persistence:
    seccompProfile:
  extraEnv:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
  extraArgs:
    - "-querier.multi-tenant-queries-enabled"
write:
  extraVolumes:
      configMap:
        items:
        defaultMode: 420
  extraVolumeMounts:
  limits_config:
  replicas: 3
  autoscaling:
    # -- Enable autoscaling for the write.
    enabled: false
    # -- Minimum autoscaling replicas for the write.
    minReplicas: 1
    # -- Maximum autoscaling replicas for the write.
    maxReplicas: 3
  persistence:
    seccompProfile:
  extraEnv:
      valueFrom:
        secretKeyRef:
      valueFrom:
        secretKeyRef:
  extraArgs:
singleBinary:
  replicas: 0
We use simple scalable mode, and I can assure you that’s not your problem.
Try putting your override configuration in the main Loki configuration (pick just one tenant for test purpose), and see if that works. Also try enable debug log for backend target and see what you get.
Also, I just noticed you have 3 replicas for backend, try lowering that to 1 and see if that works. If it does, then try adding common.compactor_address to your configuration (this should be the internal address to your backend target), then increase the replica count back to 3, and see if that works.
Hi :slight_smile:
We’ve been able to make the retention work switching to runtimeConfig like this:
loki:
  runtimeConfig:
    overrides:
      tenant1:
      tenant2:
      tenant3:
        retention_stream:
          - selector: '{k8s_cluster_name="K8S-PROD"}'
            priority: 1
            period: 24h
      tenant4:
  limits_config:
