Hello!
I am trying to integrate Loki in a k8s environment.
I would like to setup long term retention in s3 for production usage.
First of all, it is not clear for me how to configure storage by loki-stack helm chart.
I am going over this for s3 configuration:
But I cannot find loki configuration options in default values.yaml file and cannot see a clear example for storage/schema configuration in loki-stack helm installation.
storage_config exists in loki-distributed. Then I am also not clear on difference of loki-distributed and loki-stack helm charts. Is that simply ok to use loki-distributed instead of loki-stack?
Second, how do I configure long-term log retention for production (simply keep all lifetime logs in s3)?
Is that stores all the logs from 2020-05-15? How is duration period 168h (default value) related with retention?
schema_config:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: index_
period: 168h
