Hey everyone! ![]()
I’ve been using the loki-stack Helm chart for awhile now (experimenting) but now that I’d like to get it ready for production, I’m attempting to use an existing ConfigMap along with Loki’s expand-env=true:
loki:
config:
schema_config:
configs:
store: aws
object_store: s3
schema: v11
index:
prefix: loki_stack_loki_
storage_config:
aws:
s3: s3://$(AWS_ACCESS_KEY_ID):$(AWS_SECRET_ACCESS_KEY)@$(AWS_REGION)/loki-stack-loki
dynamodb:
dynamodb_url: dynamodb://$(AWS_ACCESS_KEY_ID):$(AWS_SECRET_ACCESS_KEY)@$(AWS_REGION)
extraArgs:
config.expand-env: true
target: all,table-manager
extraEnvFrom:
- configMapRef:
The problem is while running queries, I receive an HTTP 500 with the message MissingEndpoint: 'Endpoint' configuration is required for this service. If I remove the $() ENV syntax from values and replace them with the actual values (that match those in the ConfigMap), everything works properly.
I understand that the grafana/loki-stack Helm chart inherits from grafana/loki chart so I’ve been using it as a reference.
