Loki Helm Documentation Isn't Working For Me
I’m trying to follow the documentation but it doesn’t work for me. I want to use the simple scalable deployment type so I’m following this: Install the simple scalable Helm chart | Grafana Loki documentation
When I create values.yaml and paste in the values provided, replacing the endpoint and credentials with my local Minio instance, then run helm install loki grafana/loki --values values.yaml it returns “Error: INSTALLATION FAILED: execution error at (loki/templates/validate.yaml:40:4): You must provide a schema_config for Loki, one is not provided as this will be individual for every Loki cluster. See Storage schema | Grafana Loki documentation for schema information. For quick testing (with no persistence) add --set loki.useTestSchema=true
Taking this further, I decided to grab the values from the chart with helm show values grafana/loki > values.yaml and then updated the values in loki.storage.s3 along with adding a schemaConfig. When trying to deploy that, I get a different error:
rror: INSTALLATION FAILED: template: loki/templates/write/statefulset-write.yaml:50:28: executing "loki/templates/write/statefulset-write.yaml" at <include (print .Template.BasePath "/config.yaml") .>: error calling include: template: loki/templates/config.yaml:19:7: executing "loki/templates/config.yaml" at <include "loki.calculatedConfig" .>: error calling include: template: loki/templates/_helpers.tpl:537:24: executing "loki.calculatedConfig" at <tpl .Values.loki.config .>: error calling tpl: error during tpl function execution for "{{- if .Values.enterprise.enabled}}\n{{- tpl .Values.enterprise.config . }}\n{{- else }}\nauth_enabled: {{ .Values.loki.auth_enabled }}\n{{- end }}\n\n{{- with .Values.loki.server }}\nserver:\n  {{- toYaml . | nindent 2}}\n{{- end}}\n\npattern_ingester:\n  enabled: {{ .Values.loki.pattern_ingester.enabled }}\n\nmemberlist:\n{{- if .Values.loki.memberlistConfig }}\n  {{- toYaml .Values.loki.memberlistConfig | nindent 2 }}\n{{- else }}\n{{- if .Values.loki.extraMemberlistConfig}}\n{{- toYaml .Values.loki.extraMemberlistConfig | nindent 2}}\n{{- end }}\n  join_members:\n    - {{ include \"loki.memberlist\" . }}\n    {{- with .Values.migrate.fromDistributed }}\n    {{- if .enabled }}\n    - {{ .memberlistService }}\n    {{- end }}\n    {{- end }}\n{{- end }}\n\n{{- with .Values.loki.ingester }}\ningester:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- if .Values.loki.commonConfig}}\ncommon:\n{{- toYaml .Values.loki.commonConfig | nindent 2}}\n  storage:\n  {{- include \"loki.commonStorageConfig\" . | nindent 4}}\n{{- end}}\n\n{{- with .Values.loki.limits_config }}\nlimits_config:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\nruntime_config:\n  file: /etc/loki/runtime-config/runtime-config.yaml\n\n{{- with .Values.chunksCache }}\n{{- if .enabled }}\nchunk_store_config:\n  chunk_cache_config:\n    default_validity: {{ .defaultValidity }}\n    background:\n      writeback_goroutines: {{ .writebackParallelism }}\n      writeback_buffer: {{ .writebackBuffer }}\n      writeback_size_limit: {{ .writebackSizeLimit }}\n    memcached:\n      batch_size: {{ .batchSize }}\n      parallelism: {{ .parallelism }}\n    memcached_client:\n      addresses: dnssrvnoa+_memcached-client._tcp.{{ template \"loki.fullname\" $ }}-chunks-cache.{{ $.Release.Namespace }}.svc\n      consistent_hash: true\n      timeout: {{ .timeout }}\n      max_idle_conns: 72\n{{- end }}\n{{- end }}\n\n{{- if .Values.loki.schemaConfig }}\nschema_config:\n{{- toYaml .Values.loki.schemaConfig | nindent 2}}\n{{- end }}\n\n{{- if .Values.loki.useTestSchema }}\nschema_config:\n{{- toYaml .Values.loki.testSchemaConfig | nindent 2}}\n{{- end }}\n\n{{ include \"loki.rulerConfig\" . }}\n\n{{- if or .Values.tableManager.retention_deletes_enabled .Values.tableManager.retention_period }}\ntable_manager:\n  retention_deletes_enabled: {{ .Values.tableManager.retention_deletes_enabled }}\n  retention_period: {{ .Values.tableManager.retention_period }}\n{{- end }}\n\nquery_range:\n  align_queries_with_step: true\n  {{- with .Values.loki.query_range }}\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n  {{- end }}\n  {{- if .Values.resultsCache.enabled }}\n  {{- with .Values.resultsCache }}\n  cache_results: true\n  results_cache:\n    cache:\n      default_validity: {{ .defaultValidity }}\n      background:\n        writeback_goroutines: {{ .writebackParallelism }}\n        writeback_buffer: {{ .writebackBuffer }}\n        writeback_size_limit: {{ .writebackSizeLimit }}\n      memcached_client:\n        consistent_hash: true\n        addresses: dnssrvnoa+_memcached-client._tcp.{{ template \"loki.fullname\" $ }}-results-cache.{{ $.Release.Namespace }}.svc\n        timeout: {{ .timeout }}\n        update_interval: 1m\n  {{- end }}\n  {{- end }}\n\n{{- with .Values.loki.storage_config }}\nstorage_config:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.query_scheduler }}\nquery_scheduler:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.compactor }}\ncompactor:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.analytics }}\nanalytics:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.querier }}\nquerier:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.index_gateway }}\nindex_gateway:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend }}\nfrontend:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend_worker }}\nfrontend_worker:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.distributor }}\ndistributor:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\ntracing:\n  enabled: {{ .Values.loki.tracing.enabled }}\n": template: gotpl:40:6: executing "gotpl" at <include "loki.commonStorageConfig" .>: error calling include: template: loki/templates/_helpers.tpl:228:19: executing "loki.commonStorageConfig" at <$.Values.loki.storage.bucketNames.chunks>: nil pointer evaluating interface {}.chunks
I read that someone had to enable the built in minio, so I tried setting that to true and it seemed to deploy the chart after that. I don’t want to use the built in Minio, I want to use my existing Minio instance. How can I accomplish this? I don’t understand the helm chart and the documentation doesn’t go into enough detail.
Hi @linucksrox, really sorry you are struggling here. There where some recent changes to the Loki helm which put this part of the docs out of date. Currently updating. To help in the mean time:
This works on my end for simple scalable using minIO
helm install loki grafana/loki -f ./loki/values.yaml --version 6.6.2
Thank you. The values.yaml you provided work, however that’s still using the Minio built into the chart. I want to point Loki to my pre-existing Minio instance instead, and leave minio.enabled=false in the helm chart. This is where I run into issues with the deployment.
Here is my modified version of values.yaml that is failing:
loki:
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  ingester:
    chunk_encoding: snappy
  tracing:
    enabled: true
  querier:
    # Default is 4, if you have enough memory and CPU you can increase, reduce if OOMing
    max_concurrent: 4
  storage:
    type: s3
    s3:
      s3: http://192.168.1.35:9000
      endpoint: http://192.168.1.35:9000
      region: null
      secretAccessKey: [redacted]
      accessKeyId: [redacted]
      signatureVersion: null
      s3ForcePathStyle: true
      insecure: true
#gateway:
#  ingress:
#    enabled: true
#    hosts:
#      - host: FIXME
#        paths:
#          - path: /
#            pathType: Prefix
deploymentMode: SimpleScalable
backend:
  replicas: 3
read:
  replicas: 3
write:
  replicas: 3
# Enable minio for storage
minio:
  enabled: false
# Zero out replica counts of other deployment modes
singleBinary:
  replicas: 0
ingester:
  replicas: 0
querier:
  replicas: 0
queryFrontend:
  replicas: 0
queryScheduler:
  replicas: 0
distributor:
  replicas: 0
compactor:
  replicas: 0
indexGateway:
  replicas: 0
bloomCompactor:
  replicas: 0
bloomGateway:
  replicas: 0
Hi @linucksrox,
Aaah thank you for explaining further. Do you have any further logs ? or do you still receive the original message in your post based on the new config?
Hi @jayclifford,
I think it’s the same message.
Error: INSTALLATION FAILED: template: loki/templates/write/statefulset-write.yaml:50:28: executing "loki/templates/write/statefulset-write.yaml" at <include (print .Template.BasePath "/config.yaml") .>: error calling include: template: loki/templates/config.yaml:19:7: executing "loki/templates/config.yaml" at <include "loki.calculatedConfig" .>: error calling include: template: loki/templates/_helpers.tpl:537:24: executing "loki.calculatedConfig" at <tpl .Values.loki.config .>: error calling tpl: error during tpl function execution for "{{- if .Values.enterprise.enabled}}\n{{- tpl .Values.enterprise.config . }}\n{{- else }}\nauth_enabled: {{ .Values.loki.auth_enabled }}\n{{- end }}\n\n{{- with .Values.loki.server }}\nserver:\n  {{- toYaml . | nindent 2}}\n{{- end}}\n\npattern_ingester:\n  enabled: {{ .Values.loki.pattern_ingester.enabled }}\n\nmemberlist:\n{{- if .Values.loki.memberlistConfig }}\n  {{- toYaml .Values.loki.memberlistConfig | nindent 2 }}\n{{- else }}\n{{- if .Values.loki.extraMemberlistConfig}}\n{{- toYaml .Values.loki.extraMemberlistConfig | nindent 2}}\n{{- end }}\n  join_members:\n    - {{ include \"loki.memberlist\" . }}\n    {{- with .Values.migrate.fromDistributed }}\n    {{- if .enabled }}\n    - {{ .memberlistService }}\n    {{- end }}\n    {{- end }}\n{{- end }}\n\n{{- with .Values.loki.ingester }}\ningester:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- if .Values.loki.commonConfig}}\ncommon:\n{{- toYaml .Values.loki.commonConfig | nindent 2}}\n  storage:\n  {{- include \"loki.commonStorageConfig\" . | nindent 4}}\n{{- end}}\n\n{{- with .Values.loki.limits_config }}\nlimits_config:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\nruntime_config:\n  file: /etc/loki/runtime-config/runtime-config.yaml\n\n{{- with .Values.chunksCache }}\n{{- if .enabled }}\nchunk_store_config:\n  chunk_cache_config:\n    default_validity: {{ .defaultValidity }}\n    background:\n      writeback_goroutines: {{ .writebackParallelism }}\n      writeback_buffer: {{ .writebackBuffer }}\n      writeback_size_limit: {{ .writebackSizeLimit }}\n    memcached:\n      batch_size: {{ .batchSize }}\n      parallelism: {{ .parallelism }}\n    memcached_client:\n      addresses: dnssrvnoa+_memcached-client._tcp.{{ template \"loki.fullname\" $ }}-chunks-cache.{{ $.Release.Namespace }}.svc\n      consistent_hash: true\n      timeout: {{ .timeout }}\n      max_idle_conns: 72\n{{- end }}\n{{- end }}\n\n{{- if .Values.loki.schemaConfig }}\nschema_config:\n{{- toYaml .Values.loki.schemaConfig | nindent 2}}\n{{- end }}\n\n{{- if .Values.loki.useTestSchema }}\nschema_config:\n{{- toYaml .Values.loki.testSchemaConfig | nindent 2}}\n{{- end }}\n\n{{ include \"loki.rulerConfig\" . }}\n\n{{- if or .Values.tableManager.retention_deletes_enabled .Values.tableManager.retention_period }}\ntable_manager:\n  retention_deletes_enabled: {{ .Values.tableManager.retention_deletes_enabled }}\n  retention_period: {{ .Values.tableManager.retention_period }}\n{{- end }}\n\nquery_range:\n  align_queries_with_step: true\n  {{- with .Values.loki.query_range }}\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n  {{- end }}\n  {{- if .Values.resultsCache.enabled }}\n  {{- with .Values.resultsCache }}\n  cache_results: true\n  results_cache:\n    cache:\n      default_validity: {{ .defaultValidity }}\n      background:\n        writeback_goroutines: {{ .writebackParallelism }}\n        writeback_buffer: {{ .writebackBuffer }}\n        writeback_size_limit: {{ .writebackSizeLimit }}\n      memcached_client:\n        consistent_hash: true\n        addresses: dnssrvnoa+_memcached-client._tcp.{{ template \"loki.fullname\" $ }}-results-cache.{{ $.Release.Namespace }}.svc\n        timeout: {{ .timeout }}\n        update_interval: 1m\n  {{- end }}\n  {{- end }}\n\n{{- with .Values.loki.storage_config }}\nstorage_config:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.query_scheduler }}\nquery_scheduler:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.compactor }}\ncompactor:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.analytics }}\nanalytics:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.querier }}\nquerier:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.index_gateway }}\nindex_gateway:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend }}\nfrontend:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend_worker }}\nfrontend_worker:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.distributor }}\ndistributor:\n  {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\ntracing:\n  enabled: {{ .Values.loki.tracing.enabled }}\n": template: gotpl:40:6: executing "gotpl" at <include "loki.commonStorageConfig" .>: error calling include: template: loki/templates/_helpers.tpl:228:19: executing "loki.commonStorageConfig" at <$.Values.loki.storage.bucketNames.chunks>: nil pointer evaluating interface {}.chunks
Hi @linucksrox,
Okay will test on my end and get you a solution
Okay belive I have fixed it:
loki:
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  ingester:
  tracing:
    enabled: true
  querier:
    max_concurrent: 4
  storage:
    type: s3
    bucketNames:
      chunks: "chunks"
      ruler: "ruler"
      admin: "admin"
    s3:
      s3: http://minio-operator:9090
      endpoint: http://minio-operator:9090
      accessKeyId: "AIbzZUHczp8q3qsC"
      secretAccessKey: "ia2YH6QGUZq93fWeiJedNtN3MpCIA4bP"
      insecure: true
deploymentMode: Distributed
ingester:
  replicas: 3
querier:
  replicas: 3
  maxUnavailable: 2
queryFrontend:
  replicas: 2
  maxUnavailable: 1
queryScheduler:
  replicas: 2
distributor:
  replicas: 3
  maxUnavailable: 2
compactor:
  replicas: 1
indexGateway:
  replicas: 2
  maxUnavailable: 1
bloomCompactor:
  replicas: 0
bloomGateway:
  replicas: 0
backend:
  replicas: 0
read:
  replicas: 0
write:
  replicas: 0
singleBinary:
  replicas: 0
It appeared there was some weird nesting in the bucketNames
@jayclifford thank you! That works for me! I had to change back to SimpleScalable mode and adjust the number of replicas for the individual components but it is deploying now. My next step will be figuring out how to run grafana and integrate loki, but I’m good with learning that on my own unless you have some suggestions there!
Thanks again!
Hi @linucksrox,
Really glad it worked out :smiling_face:! Sounds awesome, I believe I can help you out a little there. So Grafana does have its own helm. The OSS build isn’t natively HA but does give you a nice deployment method. Deploy Grafana using Helm Charts | Grafana documentation
The helm is currently 1 version behind (10.4) Grafana 11 is now released.
Although looking after the discussion on loki helm chart I am facing an issue while installing the loki through helm.
This is my preferred helm chart: loki 6.7.3 · grafana/grafana
loki:
  auth_enabled: false
  storage:
    bucketNames:
      chunks: infix-ue1-ifx-d-s3
      ruler: infix-ue1-ifx-d-s3
      admin: infix-ue1-ifx-d-s3
    type: s3
    s3:
      s3: s3://infix-ue1-ifx-d-s3/grafana/
      endpoint: null
      region: us-east-1
      secretAccessKey: null
      accessKeyId: null
      s3ForcePathStyle: false
      insecure: false
      http_config: {}
  schemaConfig:
    configs:
        index:
          period: 24h
          prefix: loki_ops_index_
        object_store: s3
        schema: v13
        store: tsdb
  useTestSchema: false
serviceAccount:
  create: false
# RBAC configuration
rbac:
  pspEnabled: false
  sccEnabled: false
  namespaced: false
# Configuration for the gateway
gateway:
  # -- Specifies whether the gateway should be enabled
  enabled: false
This is my values.yml.
I am getting the error
Error: create: failed to create: Request entity too large: limit is 3145728
When looking into the local helm cache directory in /home/mukesh/.cache/helm/repository I found that the added repo is of greater size than that of limit.
How can I reduce the size of chart that I am fetching from artifact hub.
Thank You !!
Hello there,
I am still facing the “nil pointer evaluating interface {}.chunks” issue on my end…I tried installing version 6.6.6, 6.8.0 and 6.9.0…not sure what could be the problem…
loki:
schemaConfig:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: loki_index_
period: 24h
ingester:
tracing:
enabled: true
querier:
max_concurrent: 4
storage:
type: s3
bucketNames:
chunks: “chunks”
ruler: “ruler”
admin: “admin”
s3:
accessKeyId: “AIbzZUHczp8q3qsC”
secretAccessKey: “ia2YH6QGUZq93fWeiJedNtN3MpCIA4bP”
insecure: true
Error: template: loki/charts/loki/templates/write/statefulset-write.yaml:50:28: executing “loki/charts/loki/templates/write/statefulset-write.yaml” at <include (print .Template.BasePath “/config.yaml”) .>: error calling include: template: loki/charts/loki/templates/config.yaml:19:7: executing “loki/charts/loki/templates/config.yaml” at <include “loki.calculatedConfig” .>: error calling include: template: loki/charts/loki/templates/_helpers.tpl:537:24: executing “loki.calculatedConfig” at <tpl .Values.loki.config .>: error calling tpl: error during tpl function execution for “{{- if .Values.enterprise.enabled}}\n{{- tpl .Values.enterprise.config . }}\n{{- else }}\nauth_enabled: {{ .Values.loki.auth_enabled }}\n{{- end }}\n\n{{- with .Values.loki.server }}\nserver:\n {{- toYaml . | nindent 2}}\n{{- end}}\n\npattern_ingester:\n enabled: {{ .Values.loki.pattern_ingester.enabled }}\n\nmemberlist:\n{{- if .Values.loki.memberlistConfig }}\n {{- toYaml .Values.loki.memberlistConfig | nindent 2 }}\n{{- else }}\n{{- if .Values.loki.extraMemberlistConfig}}\n{{- toYaml .Values.loki.extraMemberlistConfig | nindent 2}}\n{{- end }}\n join_members:\n - {{ include "loki.memberlist" . }}\n {{- with .Values.migrate.fromDistributed }}\n {{- if .enabled }}\n - {{ .memberlistService }}\n {{- end }}\n {{- end }}\n{{- end }}\n\n{{- with .Values.loki.ingester }}\ningester:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- if .Values.loki.commonConfig}}\ncommon:\n{{- toYaml .Values.loki.commonConfig | nindent 2}}\n storage:\n {{- include "loki.commonStorageConfig" . | nindent 4}}\n{{- end}}\n\n{{- with .Values.loki.limits_config }}\nlimits_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\nruntime_config:\n file: /etc/loki/runtime-config/runtime-config.yaml\n\n{{- with .Values.chunksCache }}\n{{- if .enabled }}\nchunk_store_config:\n chunk_cache_config:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached:\n batch_size: {{ .batchSize }}\n parallelism: {{ .parallelism }}\n memcached_client:\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template "loki.fullname" $ }}-chunks-cache.{{ $.Release.Namespace }}.svc\n consistent_hash: true\n timeout: {{ .timeout }}\n max_idle_conns: 72\n{{- end }}\n{{- end }}\n\n{{- if .Values.loki.schemaConfig }}\nschema_config:\n{{- toYaml .Values.loki.schemaConfig | nindent 2}}\n{{- end }}\n\n{{- if .Values.loki.useTestSchema }}\nschema_config:\n{{- toYaml .Values.loki.testSchemaConfig | nindent 2}}\n{{- end }}\n\n{{ include "loki.rulerConfig" . }}\n\n{{- if or .Values.tableManager.retention_deletes_enabled .Values.tableManager.retention_period }}\ntable_manager:\n retention_deletes_enabled: {{ .Values.tableManager.retention_deletes_enabled }}\n retention_period: {{ .Values.tableManager.retention_period }}\n{{- end }}\n\nquery_range:\n align_queries_with_step: true\n {{- with .Values.loki.query_range }}\n {{- tpl (. | toYaml) $ | nindent 2 }}\n {{- end }}\n {{- if .Values.resultsCache.enabled }}\n {{- with .Values.resultsCache }}\n cache_results: true\n results_cache:\n cache:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached_client:\n consistent_hash: true\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template "loki.fullname" $ }}-results-cache.{{ $.Release.Namespace }}.svc\n timeout: {{ .timeout }}\n update_interval: 1m\n {{- end }}\n {{- end }}\n\n{{- with .Values.loki.storage_config }}\nstorage_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.query_scheduler }}\nquery_scheduler:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.compactor }}\ncompactor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.analytics }}\nanalytics:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.querier }}\nquerier:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.index_gateway }}\nindex_gateway:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend }}\nfrontend:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend_worker }}\nfrontend_worker:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.distributor }}\ndistributor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\ntracing:\n enabled: {{ .Values.loki.tracing.enabled }}\n”: template: gotpl:40:6: executing “gotpl” at <include “loki.commonStorageConfig” .>: error calling include: template: loki/charts/loki/templates/_helpers.tpl:228:19: executing “loki.commonStorageConfig” at <$.Values.loki.storage.bucketNames.chunks>: nil pointer evaluating interface {}.chunks
YES! Thank you. I was getting hopeless.
Still experiencing this issue using the default simple-scalable values file provided by Jay above and that is in the official repo.
Using version 6.27.0
Any help would be appreciated
Update to version 6.29.0
