I have set following values for local single process testing.
loki:
commonConfig:
replication_factor: 1
path_prefix: /tmp/loki
storage:
type: filesystem
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
admin_api_directory: /tmp/loki/admin
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
pattern_ingester:
enabled: true
limits_config:
allow_structured_metadata: true
volume_enabled: true
retention_period: 672h # 28 days retention
compactor:
retention_enabled: true
delete_request_store: filesystem
ruler:
enable_api: true
deploymentMode: SingleBinary
singleBinary:
replicas: 1
# Zero out replica counts of other deployment modes
backend:
replicas: 0
read:
replicas: 0
write:
replicas: 0
ingester:
replicas: 0
querier:
replicas: 0
queryFrontend:
replicas: 0
queryScheduler:
replicas: 0
distributor:
replicas: 0
compactor:
replicas: 0
Then this command helm install loki grafana/loki -f loki-value.yaml gave me error:
Error: INSTALLATION FAILED: template: loki/templates/single-binary/statefulset.yaml:44:28: executing "loki/templates/single-binary/statefulset.yaml" at <include (print .Template.BasePath "/config.yaml") .>: error calling include: template: loki/templates/config.yaml:19:7: executing "loki/templates/config.yaml" at <include "loki.calculatedConfig" .>: error calling include: template: loki/templates/_helpers.tpl:507:24: executing "loki.calculatedConfig" at <tpl .Values.loki.config .>: error calling tpl: error during tpl function execution for "{{- if .Values.enterprise.enabled}}\n{{- tpl .Values.enterprise.config . }}\n{{- else }}\nauth_enabled: {{ .Values.loki.auth_enabled }}\n{{- end }}\n\n{{- with .Values.loki.server }}\nserver:\n {{- toYaml . | nindent 2}}\n{{- end}}\n\npattern_ingester:\n enabled: {{ .Values.loki.pattern_ingester.enabled }}\n\nmemberlist:\n{{- if .Values.loki.memberlistConfig }}\n {{- toYaml .Values.loki.memberlistConfig | nindent 2 }}\n{{- else }}\n{{- if .Values.loki.extraMemberlistConfig}}\n{{- toYaml .Values.loki.extraMemberlistConfig | nindent 2}}\n{{- end }}\n join_members:\n - {{ include \"loki.memberlist\" . }}\n {{- with .Values.migrate.fromDistributed }}\n {{- if .enabled }}\n - {{ .memberlistService }}\n {{- end }}\n {{- end }}\n{{- end }}\n\n{{- with .Values.loki.ingester }}\ningester:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- if .Values.loki.commonConfig}}\ncommon:\n{{- toYaml .Values.loki.commonConfig | nindent 2}}\n storage:\n {{- include \"loki.commonStorageConfig\" . | nindent 4}}\n{{- end}}\n\n{{- with .Values.loki.limits_config }}\nlimits_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\nruntime_config:\n file: /etc/loki/runtime-config/runtime-config.yaml\n\n{{- with .Values.chunksCache }}\n{{- if .enabled }}\nchunk_store_config:\n chunk_cache_config:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached:\n batch_size: {{ .batchSize }}\n parallelism: {{ .parallelism }}\n memcached_client:\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template \"loki.fullname\" $ }}-chunks-cache.{{ $.Release.Namespace }}.svc\n consistent_hash: true\n timeout: {{ .timeout }}\n max_idle_conns: 72\n{{- end }}\n{{- end }}\n\n{{- if .Values.loki.schemaConfig }}\nschema_config:\n{{- toYaml .Values.loki.schemaConfig | nindent 2}}\n{{- end }}\n\n{{- if .Values.loki.useTestSchema }}\nschema_config:\n{{- toYaml .Values.loki.testSchemaConfig | nindent 2}}\n{{- end }}\n\n{{ include \"loki.rulerConfig\" . }}\n\n{{- if or .Values.tableManager.retention_deletes_enabled .Values.tableManager.retention_period }}\ntable_manager:\n retention_deletes_enabled: {{ .Values.tableManager.retention_deletes_enabled }}\n retention_period: {{ .Values.tableManager.retention_period }}\n{{- end }}\n\nquery_range:\n align_queries_with_step: true\n {{- with .Values.loki.query_range }}\n {{- tpl (. | toYaml) $ | nindent 2 }}\n {{- end }}\n {{- if .Values.resultsCache.enabled }}\n {{- with .Values.resultsCache }}\n cache_results: true\n results_cache:\n cache:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached_client:\n consistent_hash: true\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template \"loki.fullname\" $ }}-results-cache.{{ $.Release.Namespace }}.svc\n timeout: {{ .timeout }}\n update_interval: 1m\n {{- end }}\n {{- end }}\n\n{{- with .Values.loki.storage_config }}\nstorage_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.query_scheduler }}\nquery_scheduler:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.compactor }}\ncompactor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.analytics }}\nanalytics:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.querier }}\nquerier:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.index_gateway }}\nindex_gateway:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend }}\nfrontend:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend_worker }}\nfrontend_worker:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.distributor }}\ndistributor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\ntracing:\n enabled: {{ .Values.loki.tracing.enabled }}\n\n{{- with .Values.loki.bloom_build }}\nbloom_build:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.bloom_gateway }}\nbloom_gateway:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n": template: gotpl:40:6: executing "gotpl" at <include "loki.commonStorageConfig" .>: error calling include: template: loki/templates/_helpers.tpl:227:19: executing "loki.commonStorageConfig" at <$.Values.loki.storage.bucketNames.chunks>: nil pointer evaluating interface {}.chunks
What should I do?
