Not able to install Loki in AWS EKS
deploymentMode: SimpleScalable
AV:
  auth_enabled: false
  server:
    http_listen_port: 3100
    grpc_listen_port: 9096
    path_prefix: /tmp/loki
  common:
    storage:
      type: s3
      bucketNames:
        chunks: "logs-test-loki"
        ruler: "logs-test-loki"
        admin: "logs-test-loki"
      s3:
        endpoint:
        bucketname:
        region: us-east-2
        access_key_id: "YOUR_ACCESS_KEY_ID"
        secret_access_key: "YOUR_SECRET_ACCESS_KEY"
        replication_factor: 1
    ring:
      kvstore:
        store: memberlist
  schema_config:
    configs:
        store: boltdb-shipper
        object_store: filesystem
        schema: v11
        index:
          prefix: index_
          period: 24h
  memberlist:
    join_members:
      - loki:7946
While Installing this error
Error: INSTALLATION FAILED: template: loki/templates/write/statefulset-write.yaml:50:28: executing “loki/templates/write/statefulset-write.yaml” at <include (print .Template.BasePath “/config.yaml”) .>: error calling include: template: loki/templates/config.yaml:19:7: executing “loki/templates/config.yaml” at <include “loki.calculatedConfig” .>: error calling include: template: loki/templates/_helpers.tpl:461:24: executing “loki.calculatedConfig” at <tpl .Values.loki.config .>: error calling tpl: error during tpl function execution for “{{- if .Values.enterprise.enabled}}\n{{- tpl .Values.enterprise.config . }}\n{{- else }}\nauth_enabled: {{ .Values.loki.auth_enabled }}\n{{- end }}\n\n{{- with .Values.loki.server }}\nserver:\n {{- toYaml . | nindent 2}}\n{{- end}}\n\npattern_ingester:\n enabled: {{ .Values.loki.pattern_ingester.enabled }}\n\nmemberlist:\n{{- if .Values.loki.memberlistConfig }}\n {{- toYaml .Values.loki.memberlistConfig | nindent 2 }}\n{{- else }}\n{{- if .Values.loki.extraMemberlistConfig}}\n{{- toYaml .Values.loki.extraMemberlistConfig | nindent 2}}\n{{- end }}\n join_members:\n - {{ include "loki.memberlist" . }}\n {{- with .Values.migrate.fromDistributed }}\n {{- if .enabled }}\n - {{ .memberlistService }}\n {{- end }}\n {{- end }}\n{{- end }}\n\n{{- with .Values.loki.ingester }}\ningester:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- if .Values.loki.commonConfig}}\ncommon:\n{{- toYaml .Values.loki.commonConfig | nindent 2}}\n storage:\n {{- include "loki.commonStorageConfig" . | nindent 4}}\n{{- end}}\n\n{{- with .Values.loki.limits_config }}\nlimits_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\nruntime_config:\n file: /etc/loki/runtime-config/runtime-config.yaml\n\n{{- with .Values.chunksCache }}\n{{- if .enabled }}\nchunk_store_config:\n chunk_cache_config:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached:\n batch_size: {{ .batchSize }}\n parallelism: {{ .parallelism }}\n memcached_client:\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template "loki.fullname" $ }}-chunks-cache.{{ $.Release.Namespace }}.svc\n consistent_hash: true\n timeout: {{ .timeout }}\n max_idle_conns: 72\n{{- end }}\n{{- end }}\n\n{{- if .Values.loki.schemaConfig }}\nschema_config:\n{{- toYaml .Values.loki.schemaConfig | nindent 2}}\n{{- end }}\n\n{{- if .Values.loki.useTestSchema }}\nschema_config:\n{{- toYaml .Values.loki.testSchemaConfig | nindent 2}}\n{{- end }}\n\n{{ include "loki.rulerConfig" . }}\n\n{{- if or .Values.tableManager.retention_deletes_enabled .Values.tableManager.retention_period }}\ntable_manager:\n retention_deletes_enabled: {{ .Values.tableManager.retention_deletes_enabled }}\n retention_period: {{ .Values.tableManager.retention_period }}\n{{- end }}\n\nquery_range:\n align_queries_with_step: true\n {{- with .Values.loki.query_range }}\n {{- tpl (. | toYaml) $ | nindent 4 }}\n {{- end }}\n {{- if .Values.resultsCache.enabled }}\n {{- with .Values.resultsCache }}\n cache_results: true\n results_cache:\n cache:\n default_validity: {{ .defaultValidity }}\n background:\n writeback_goroutines: {{ .writebackParallelism }}\n writeback_buffer: {{ .writebackBuffer }}\n writeback_size_limit: {{ .writebackSizeLimit }}\n memcached_client:\n consistent_hash: true\n addresses: dnssrvnoa+_memcached-client._tcp.{{ template "loki.fullname" $ }}-results-cache.{{ $.Release.Namespace }}.svc\n timeout: {{ .timeout }}\n update_interval: 1m\n {{- end }}\n {{- end }}\n\n{{- with .Values.loki.storage_config }}\nstorage_config:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.query_scheduler }}\nquery_scheduler:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.compactor }}\ncompactor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.analytics }}\nanalytics:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.querier }}\nquerier:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.index_gateway }}\nindex_gateway:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend }}\nfrontend:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.frontend_worker }}\nfrontend_worker:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\n{{- with .Values.loki.distributor }}\ndistributor:\n {{- tpl (. | toYaml) $ | nindent 4 }}\n{{- end }}\n\ntracing:\n enabled: {{ .Values.loki.tracing.enabled }}\n”: template: gotpl:40:6: executing “gotpl” at <include “loki.commonStorageConfig” .>: error calling include: template: loki/templates/_helpers.tpl:228:19: executing “loki.commonStorageConfig” at <$.Values.loki.storage.bucketNames.chunks>: nil pointer evaluating interface {}.chunks
Facing similar issue, can anyone help on this?
Did you get a solution …?
Templates have changed for loki helm chart. Use new version and try to deploy it.
Did you find any solution
where’s the new version? i’ve tried the github but it still fails
