How to install Loki on (AWS) EKS using Terraform with S3
Hello everyone,
First of all, I want to apologize if this is a duplicate, but over the last couple of days, I’ve searched extensively for a solution to my problem. I’m trying to deploy Grafana Loki on AWS Elastic Kubernetes Service using Terraform in a way that utilizes S3 for storage. I’m fairly new to Kubernetes and AWS, so I’m sure I’m just overlooking something simple, but I can’t get Loki to save logs in S3. Loki starts up normally, but it doesn’t create anything in the S3 bucket, unlike what I saw in the “Deploying the Loki Helm on AWS” video from the official YouTube channel.
I’ll share my files below. If anyone could take a look at them, I’d be very grateful!
# Loki.tf
data "aws_s3_bucket" "loki_storage" {
  bucket = var.loki_bucket_chunks
resource "kubernetes_namespace" "loki" {
  metadata {
    name = "loki"
resource "helm_release" "loki" {
  name       = "loki"
  namespace  = "loki"
  repository = "https://grafana.github.io/helm-charts"
  chart      = "loki-stack"
  depends_on = [kubernetes_namespace.loki]
  timeout = 120
  wait = true
  values = [
    templatefile("${path.module}/loki-values.yaml", {
      aws_iam_role_arn = aws_iam_role.loki_role.arn,
      aws_region       = "eu-central-1",
      loki_bucket_name = data.aws_s3_bucket.loki_storage.bucket,
# IAM.tf
resource "aws_iam_role" "loki_role" {
  name = "loki-s3-access-role"
  assume_role_policy = jsonencode({
    Version = "2012-10-17"
    Statement = [
        Effect = "Allow"
        Principal = {
          Service = "eks.amazonaws.com"
        Action = "sts:AssumeRole"
resource "aws_iam_role_policy" "loki_s3_policy" {
  name = "loki-s3-policy"
  role = aws_iam_role.loki_role.id
    Statement = [
        Effect = "Allow"
        Action = [
          "s3:GetObject",
          "s3:PutObject",
          "s3:ListBucket",
          "s3:DeleteObject"
        Resource = [
          data.aws_s3_bucket.loki_storage.arn,
          "${data.aws_s3_bucket.loki_storage.arn}/*"
# loki-values.yaml
loki:
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  storage_config:
    aws:
      region: ${aws_region}
      bucketnames: ${loki_bucket_name}
      s3forcepathstyle: false
  ingester:
      chunk_encoding: snappy
  pattern_ingester:
      enabled: true
  limits_config:
      allow_structured_metadata: true
      volume_enabled: true
      retention_period: 672h
  compactor:
      retention_enabled: true
      delete_request_store: s3
  ruler:
    enable_api: true
    storage:
      type: s3
      s3:
        bucketname: ${loki_bucket_name}
        s3ForcePathStyle: false
      alertmanager_url: http://prom:9093
  storage:
    type: s3
    bucketNames:
      chunks: "${loki_bucket_name}"
      ruler: "${loki_bucket_name}"
      #admin: "${loki_bucket_name}"
    s3:
      insecure: false
serviceAccount:
  create: true
  annotations:
    "eks.amazonaws.com/role-arn": "${aws_iam_role_arn}"
deploymentMode: SimpleScalable
write:
  replicas: 1
  persistence:
    enabled: true
    storageClass: gp3
    accessModes:
      - ReadWriteOnce
read:
  replicas: 1
  persistence:
    enabled: true
    storageClass: gp3
    accessModes:
      - ReadWriteOnce
backend:
  replicas: 1
  persistence:
    enabled: true
    storageClass: gp3
    accessModes:
      - ReadWriteOnce
canary:
  enabled: false
minio:
  enabled: false
I don’t think your storage configuration is quite right. This is what our storage and index configuration looks like:
common:
  storage:
    s3:
      bucketnames: <...>
      region: <...>
      s3forcepathstyle: true
      sse:
        type: "SSE-S3"
  <OTHER_COMMON_CONFIG>
schema_config:
  configs:
    store: tsdb
    object_store: s3
    schema: v13
    index:
      prefix: index_
      period: 24h
Hey! Thank you for the message. :slight_smile:
I removed the “old” Storage and Index configuration and replaced them with yours, but unfortunately, the S3 bucket still appears empty.
May I ask which chart and version you are using?
Best wishes!
Updated YAML with tonyswumac changes
loki:
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: index_
          period: 24h
  storage_config:
    aws:
  ingester:
  pattern_ingester:
      enabled: true
  limits_config:
  compactor:
  ruler:
    enable_api: true
    storage:
      type: s3
      s3:
  common:
    storage:
      s3:
        bucketNames:
        sse:
          type: "SSE3-S3"
serviceAccount:
  create: true
  annotations:
write:
  replicas: 1
  persistence:
    enabled: true
    storageClass: gp3
    accessModes:
      - ReadWriteOnce
read:
  replicas: 1
  persistence:
    enabled: true
    storageClass: gp3
    accessModes:
      - ReadWriteOnce
backend:
  replicas: 1
  persistence:
    enabled: true
    storageClass: gp3
    accessModes:
      - ReadWriteOnce
canary:
  enabled: false
minio:
  enabled: false
Can you share your config again? Any error from the writer?
We run Loki on ECS, so we aren’t using the operator or helm chart.
Hey, sure!
This is the loki-values.yaml i use. From my understanding everything under loki is loki configuration the rest are settings for the pod. No errors from the writer. I’ll attach the Logs generated from starting loki.
Config:
loki:
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: index_
          period: 24h
  storage_config:
    aws:
  ingester:
  pattern_ingester:
      enabled: true
  limits_config:
  compactor:
  ruler:
    enable_api: true
    storage:
      type: s3
      s3:
  common:
    storage:
      s3:
        bucketNames:
        sse:
          type: "SSE3-S3"
serviceAccount:
  create: true
  annotations:
write:
  replicas: 1
  persistence:
    enabled: true
    storageClass: gp3
    accessModes:
      - ReadWriteOnce
read:
  replicas: 1
  persistence:
    enabled: true
    storageClass: gp3
    accessModes:
      - ReadWriteOnce
backend:
  replicas: 1
  persistence:
    enabled: true
    storageClass: gp3
    accessModes:
      - ReadWriteOnce
canary:
  enabled: false
minio:
  enabled: false
Logs:
level=info ts=2024-11-20T20:24:47.817499343Z caller=main.go:103 msg="Starting Loki" version="(version=2.6.1, branch=HEAD, revision=6bd05c9a4)"
level=info ts=2024-11-20T20:24:47.818082731Z caller=server.go:288 http=[::]:3100 grpc=[::]:9095 msg="server listening on addresses"
level=info ts=2024-11-20T20:24:47.81875431Z caller=modules.go:736 msg="RulerStorage is not configured in single binary mode and will not be started."
level=warn ts=2024-11-20T20:24:47.835554115Z caller=experimental.go:20 msg="experimental feature in use" feature="In-memory (FIFO) cache - chunksfifocache"
level=info ts=2024-11-20T20:24:47.838381745Z caller=table_manager.go:252 msg="query readiness setup completed" duration=3.56µs distinct_users_len=0
level=info ts=2024-11-20T20:24:47.838555526Z caller=shipper.go:124 msg="starting index shipper in RW mode"
level=info ts=2024-11-20T20:24:47.840084808Z caller=shipper_index_client.go:79 msg="starting boltdb shipper in RW mode"
level=info ts=2024-11-20T20:24:47.845702757Z caller=worker.go:112 msg="Starting querier worker using query-scheduler and scheduler ring for addresses"
ts=2024-11-20T20:24:47.846469437Z caller=memberlist_logger.go:74 level=warn msg="Failed to resolve loki-memberlist: lookup loki-memberlist on 10.100.0.10:53: no such host"
level=info ts=2024-11-20T20:24:47.847276529Z caller=table_manager.go:134 msg="uploading tables"
level=info ts=2024-11-20T20:24:47.847338619Z caller=table_manager.go:167 msg="handing over indexes to shipper"
level=info ts=2024-11-20T20:24:47.84886251Z caller=modules.go:761 msg="RulerStorage is nil.  Not starting the ruler."
level=info ts=2024-11-20T20:24:47.854790403Z caller=module_service.go:82 msg=initialising module=server
level=info ts=2024-11-20T20:24:47.85741054Z caller=module_service.go:82 msg=initialising module=query-frontend-tripperware
level=info ts=2024-11-20T20:24:47.857931707Z caller=module_service.go:82 msg=initialising module=memberlist-kv
level=info ts=2024-11-20T20:24:47.85814035Z caller=module_service.go:82 msg=initialising module=store
level=info ts=2024-11-20T20:24:47.858193871Z caller=module_service.go:82 msg=initialising module=ring
level=info ts=2024-11-20T20:24:47.858321293Z caller=ring.go:263 msg="ring doesn't exist in KV store yet"
level=info ts=2024-11-20T20:24:47.858398084Z caller=module_service.go:82 msg=initialising module=ingester-querier
level=info ts=2024-11-20T20:24:47.858491395Z caller=module_service.go:82 msg=initialising module=usage-report
level=info ts=2024-11-20T20:24:47.859152754Z caller=module_service.go:82 msg=initialising module=compactor
level=info ts=2024-11-20T20:24:47.859423298Z caller=ring.go:263 msg="ring doesn't exist in KV store yet"
level=info ts=2024-11-20T20:24:47.85954905Z caller=module_service.go:82 msg=initialising module=distributor
level=info ts=2024-11-20T20:24:47.859825684Z caller=module_service.go:82 msg=initialising module=ingester
level=info ts=2024-11-20T20:24:47.859864654Z caller=ingester.go:401 msg="recovering from checkpoint"
level=info ts=2024-11-20T20:24:47.860036217Z caller=recovery.go:39 msg="no checkpoint found, treating as no-op"
level=info ts=2024-11-20T20:24:47.860220809Z caller=module_service.go:82 msg=initialising module=query-scheduler
level=info ts=2024-11-20T20:24:47.860370802Z caller=ring.go:263 msg="ring doesn't exist in KV store yet"
level=info ts=2024-11-20T20:24:47.860550994Z caller=basic_lifecycler.go:261 msg="instance not found in the ring" instance=loki-0 ring=compactor
level=info ts=2024-11-20T20:24:47.860798227Z caller=basic_lifecycler_delegates.go:63 msg="not loading tokens from file, tokens file path is empty"
level=info ts=2024-11-20T20:24:47.861096782Z caller=lifecycler.go:547 msg="not loading tokens from file, tokens file path is empty"
level=info ts=2024-11-20T20:24:47.861154212Z caller=lifecycler.go:576 msg="instance not found in ring, adding with no tokens" ring=distributor
level=info ts=2024-11-20T20:24:47.861323025Z caller=lifecycler.go:416 msg="auto-joining cluster after timeout" ring=distributor
level=info ts=2024-11-20T20:24:47.861604538Z caller=basic_lifecycler.go:261 msg="instance not found in the ring" instance=loki-0 ring=scheduler
level=info ts=2024-11-20T20:24:47.861657639Z caller=basic_lifecycler_delegates.go:63 msg="not loading tokens from file, tokens file path is empty"
level=info ts=2024-11-20T20:24:47.861618759Z caller=ingester.go:417 msg="recovered WAL checkpoint recovery finished" elapsed=1.765065ms errors=false
level=info ts=2024-11-20T20:24:47.861974784Z caller=ingester.go:423 msg="recovering from WAL"
level=info ts=2024-11-20T20:24:47.861950304Z caller=scheduler.go:617 msg="waiting until scheduler is JOINING in the ring"
level=info ts=2024-11-20T20:24:47.86237185Z caller=scheduler.go:621 msg="scheduler is JOINING in the ring"
level=info ts=2024-11-20T20:24:47.862005214Z caller=compactor.go:307 msg="waiting until compactor is JOINING in the ring"
level=info ts=2024-11-20T20:24:47.862624903Z caller=compactor.go:311 msg="compactor is JOINING in the ring"
level=info ts=2024-11-20T20:24:47.862538051Z caller=ingester.go:439 msg="WAL segment recovery finished" elapsed=2.684007ms errors=false
level=info ts=2024-11-20T20:24:47.862793586Z caller=ingester.go:387 msg="closing recoverer"
level=info ts=2024-11-20T20:24:47.862814206Z caller=ingester.go:395 msg="WAL recovery finished" time=2.960152ms
level=info ts=2024-11-20T20:24:47.862924657Z caller=lifecycler.go:547 msg="not loading tokens from file, tokens file path is empty"
level=info ts=2024-11-20T20:24:47.863329083Z caller=lifecycler.go:576 msg="instance not found in ring, adding with no tokens" ring=ingester
level=info ts=2024-11-20T20:24:47.863499155Z caller=lifecycler.go:416 msg="auto-joining cluster after timeout" ring=ingester
level=info ts=2024-11-20T20:24:47.863718688Z caller=wal.go:156 msg=started component=wal
level=info ts=2024-11-20T20:24:48.863476132Z caller=compactor.go:321 msg="waiting until compactor is ACTIVE in the ring"
level=info ts=2024-11-20T20:24:48.863650854Z caller=compactor.go:325 msg="compactor is ACTIVE in the ring"
level=info ts=2024-11-20T20:24:48.863487702Z caller=scheduler.go:631 msg="waiting until scheduler is ACTIVE in the ring"
level=info ts=2024-11-20T20:24:48.86406724Z caller=scheduler.go:635 msg="scheduler is ACTIVE in the ring"
level=info ts=2024-11-20T20:24:48.864189441Z caller=module_service.go:82 msg=initialising module=query-frontend
level=info ts=2024-11-20T20:24:48.864375704Z caller=module_service.go:82 msg=initialising module=querier
level=info ts=2024-11-20T20:24:48.864556517Z caller=loki.go:374 msg="Loki started"
level=info ts=2024-11-20T20:24:48.940617848Z caller=memberlist_client.go:563 msg="joined memberlist cluster" reached_nodes=1
level=info ts=2024-11-20T20:24:51.864477531Z caller=scheduler.go:682 msg="this scheduler is in the ReplicationSet, will now accept requests."
level=info ts=2024-11-20T20:24:51.864591223Z caller=worker.go:209 msg="adding connection" addr=172.31.32.17:9095
level=info ts=2024-11-20T20:24:53.864022088Z caller=compactor.go:386 msg="this instance has been chosen to run the compactor, starting compactor"
level=info ts=2024-11-20T20:24:53.864212791Z caller=compactor.go:413 msg="waiting 10m0s for ring to stay stable and previous compactions to finish before starting compactor"
level=info ts=2024-11-20T20:24:58.864805787Z caller=frontend_scheduler_worker.go:101 msg="adding connection to scheduler" addr=172.31.32.17:9095
level=info ts=2024-11-20T20:25:47.84842321Z caller=table_manager.go:167 msg="handing over indexes to shipper"
level=info ts=2024-11-20T20:25:47.848504991Z caller=table_manager.go:134 msg="uploading tables"
  1. You are defining the same S3 bucket twice. I’d say try to do either common.storage (my approach), or just do storage_config. The key is that object_store under your index configuration needs to point to a valid storage. You can see an example on the helm chart’s documentation here: helm-charts/charts/loki-distributed at main · grafana/helm-charts · GitHub
  2. Hit up your Loki container’s /config endpoint if you are not sure what the run-time configuration looks like.
  3. Can you confirm the chunk files are written to the container’s filesystem? If so then it’s a config error. If not then your problem may be elsewhere.
