I am new to helm , prometheus-grafana and loki services.
I have installed loki-stack in my eks cluster through helm chart for log monitoring of my eks pods by using the below command.
helm install loki-stack grafana/loki-stack -n monitoring
loki-chunks folder is getting saved in one of the eks node , which eventually causing high memory consumption.
I did some work around that if we can save the chunks folder in s3 bucket or not.
I got few answers, that in loki values.yaml file we can mention s3 details for s3 implementation , which is mentioned here https://stackoverflow.com/questions/71959031/how-to-use-s3-as-storage-for-loki-logs.
But if i am passing the command helm inspect values grafana/loki-stack >> values.yaml
I am getting below response.
loki:
enabled: true
isDefault: true
promtail:
enabled: true
config:
lokiAddress: http://{{ .Release.Name }}:3100/loki/api/v1/push
fluent-bit:
enabled: false
grafana:
enabled: false
sidecar:
datasources:
enabled: true
maxLines: 1000
image:
tag: 8.3.5
prometheus:
enabled: false
isDefault: false
filebeat:
enabled: false
filebeatConfig:
filebeat.yml: |
# logging.level: debug
filebeat.inputs:
- type: container
paths:
- /var/log/containers/*.log
processors:
- add_kubernetes_metadata:
host: ${NODE_NAME}
matchers:
- logs_path:
logs_path: "/var/log/containers/"
output.logstash:
hosts: ["logstash-loki:5044"]
logstash:
enabled: false
image: grafana/logstash-output-loki
imageTag: 1.0.1
filters:
main: |-
filter {
if [kubernetes] {
mutate {
add_field => {
"container_name" => "%{[kubernetes][container][name]}"
"namespace" => "%{[kubernetes][namespace]}"
"pod" => "%{[kubernetes][pod][name]}"
replace => { "host" => "%{[kubernetes][node][name]}"}
mutate {
remove_field => ["tags"]
outputs:
main: |-
output {
loki {
url => "http://loki:3100/loki/api/v1/push"
#username => "test"
#password => "test"
# stdout { codec => rubydebug }
I am not getting where to mention the s3 configurations in the above values.yaml file.
Can some one help ?
It will be really appreciable.
Thanks.
