Loki gives empty responses when querying from Grafana
Using the loki-distributed helm chart to install loki as well as the promtail helm chart. The loki services do not appear to be pushing their data to the s3 bucket and also do not appear to be sharing state with each other as their caches/index directories are empty.
Loki Config is shown here:
auth_enabled: false
server:
  http_listen_port: 3100
distributor:
  ring:
    kvstore:
      store: memberlist
memberlist:
  join_members:
    - loki-distributed-memberlist
ingester:
  lifecycler:
    ring:
      kvstore:
        store: memberlist
      replication_factor: 1
  chunk_idle_period: 30m
  chunk_block_size: 262144
  chunk_encoding: snappy
  chunk_retain_period: 1m
  max_transfer_retries: 0
limits_config:
  enforce_metric_name: false
  reject_old_samples: true
  max_cache_freshness_per_query: 10m
schema_config:
  configs:
      store: boltdb-shipper
      object_store: aws
      schema: v11
      index:
        prefix: loki_index_
        period: 24h
storage_config:
  aws:
    s3: s3://${s3_bucket_region}
    bucketnames: ${s3_bucket_name}
    access_key_id: ${access_key_id}
    secret_access_key: ${secret_access_key}
  boltdb_shipper:
    active_index_directory: /var/loki/index
    shared_store: s3
    cache_location: /var/loki/cache
chunk_store_config:
  max_look_back_period: 0s
table_manager:
  retention_deletes_enabled: false
  retention_period: 0s
query_range:
  align_queries_with_step: true
  max_retries: 5
  split_queries_by_interval: 15m
  cache_results: true
  results_cache:
    cache:
      enable_fifocache: true
      fifocache:
        max_size_items: 1024
        validity: 24h
frontend_worker:
  frontend_address: loki-distributed-query-frontend:9095
frontend:
  log_queries_longer_than: 5s
  compress_responses: true
  tail_proxy_url: http://loki-distributed-querier:3100
compactor:
  shared_store: s3
ruler:
  storage:
    type: s3
    s3:
  ring:
    kvstore:
      store: memberlist
  rule_path: /tmp/loki/scratch
  alertmanager_url: https://alertmanager.xx
  external_url: https://alertmanager.xx
