loki:
schemaConfig:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: loki_index_
period: 24h
storage_config:
aws:
s3: null
endpoint: ###################
region: local
bucketnames: loki
secret_access_key: ###############
access_key_id: loki
s3forcepathstyle: true
insecure: true
ingester:
chunk_encoding: snappy
pattern_ingester:
enabled: true
limits_config:
reject_old_samples: true
max_cache_freshness_per_query: 10m
split_queries_by_interval: 15m
query_timeout: 300s
querier:
max_concurrent: 4
storage:
type: s3
bucketNames:
chunks: "loki"
ruler: "loki"
admin: "loki"
s3:
s3: null
endpoint: #############################
region: local
secretAccessKey: #######################
accessKeyId: loki-dev
signatureVersion: v4
s3ForcePathStyle: true
insecure: true
http_config: {}
deploymentMode: Distributed
# Disable minio storage
minio:
enabled: false
ingester:
replicas: 3
zoneAwareReplication:
enabled: false
affinity:
podAntiAffinity:
requiredDuringSchedulingIgnoredDuringExecution: []
preferredDuringSchedulingIgnoredDuringExecution:
- weight: 20
podAffinityTerm:
labelSelector:
matchLabels:
app.kubernetes.io/component: ingester
topologyKey: kubernetes.io/hostname
querier:
replicas: 3
maxUnavailable: 2
affinity:
podAntiAffinity:
- weight: 20
podAffinityTerm:
labelSelector:
matchLabels:
app.kubernetes.io/component: querier
queryFrontend:
replicas: 2
maxUnavailable: 1
affinity:
podAntiAffinity:
- weight: 20
podAffinityTerm:
labelSelector:
matchLabels:
app.kubernetes.io/component: query-frontend
queryScheduler:
replicas: 2
affinity:
podAntiAffinity:
- weight: 20
podAffinityTerm:
labelSelector:
matchLabels:
app.kubernetes.io/component: query-scheduler
distributor:
replicas: 3
maxUnavailable: 2
affinity:
podAntiAffinity:
- weight: 20
podAffinityTerm:
labelSelector:
matchLabels:
app.kubernetes.io/component: distributor
compactor:
replicas: 1
affinity:
podAntiAffinity:
- weight: 20
podAffinityTerm:
labelSelector:
matchLabels:
app.kubernetes.io/component: compactor
indexGateway:
replicas: 2
maxUnavailable: 1
affinity:
podAntiAffinity:
- weight: 20
podAffinityTerm:
labelSelector:
matchLabels:
app.kubernetes.io/component: index-gateway
bloomPlanner:
replicas: 0
bloomBuilder:
replicas: 0
bloomGateway:
replicas: 0
backend:
replicas: 0
read:
replicas: 0
write:
replicas: 0
singleBinary:
replicas: 0
Using rke2 environment k8s.
