b0b
November 10, 2021, 3:06pm
1
Hello all,
after getting the everything working with a single node deploy with the help I got in Can't get tracing with Grafana Agent to work
Now I’m trying the fully distributed Loki stack, deploying using grafana/loki-distributed helm chart
All my pods are now up and running, which is a first step
$ kubectl get pods -n loki
NAME READY STATUS RESTARTS AGE
loki-distributed-compactor-9b98f7f6-kc9zn 1/1 Running 0 46h
loki-distributed-distributor-9c5c686b7-ms9p2 1/1 Running 0 23h
loki-distributed-gateway-6dd5459c95-2674d 1/1 Running 0 2d
loki-distributed-index-gateway-0 1/1 Running 0 46h
loki-distributed-index-gateway-1 1/1 Running 0 46h
loki-distributed-ingester-0 1/1 Running 0 46h
loki-distributed-querier-74c47c4d95-bjgzd 1/1 Running 0 46h
loki-distributed-query-frontend-57789d8bcd-4mw65 1/1 Running 0 46h
I’m using grafana-agent to ship my logs. Based on metrics, messages seem to be sent on. These numbers are increasing.
$ curl -s http://localhost:8080/metrics | grep promtail_sent_
# HELP promtail_sent_bytes_total Number of bytes sent.
# TYPE promtail_sent_bytes_total counter
promtail_sent_bytes_total{host="loki-distributed-distributor.loki:3100"} 27496
# HELP promtail_sent_entries_total Number of log entries sent to the ingester.
# TYPE promtail_sent_entries_total counter
promtail_sent_entries_total{host="loki-distributed-distributor.loki:3100"} 1285
For Distributor and Ingester, what should I be looking for. I don’t see anything too suspicious in logs and no idea what metrics I should be looking out for.
In AWS console, my S3 bucket looks empty. Maybe that is not the way to verify the writes?
All suggestions welcome
b0b
November 11, 2021, 8:24am
2
Here is the full ConfigMap, in case it shows something that is set wrong
$ kubectl describe configmap loki-distributed -n loki
Namespace: loki
Labels: app.kubernetes.io/instance=loki-distributed
app.kubernetes.io/managed-by=Helm
app.kubernetes.io/name=loki-distributed
app.kubernetes.io/version=2.3.0
helm.sh/chart=loki-distributed-0.37.3
Annotations: meta.helm.sh/release-name: loki-distributed
meta.helm.sh/release-namespace: loki
Data
config.yaml:
auth_enabled: false
server:
http_listen_port: 3100
distributor:
ring:
kvstore:
store: memberlist
memberlist:
join_members:
- loki-distributed-memberlist
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 1
chunk_idle_period: 30m
chunk_block_size: 262144
chunk_encoding: snappy
chunk_retain_period: 1m
max_transfer_retries: 0
limits_config:
enforce_metric_name: false
reject_old_samples: true
max_cache_freshness_per_query: 10m
schema_config:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: loki_index_
period: 24h
storage_config:
boltdb_shipper:
active_index_directory: /var/loki/index
cache_location: /var/loki/cache
shared_store: s3
cache_ttl: 168h
index_gateway_client:
server_address: dns:///loki-distributed-index-gateway:9095
aws:
bucketnames: my-s3-bucket-name
region: eu-west-1
access_key_id: ${LOKI_S3_ACCESS_KEY_ID}
secret_access_key: ${LOKI_S3_SECRET_ACCESS_KEY}
insecure: false
sse_encryption: false
http_config:
idle_conn_timeout: 90s
response_header_timeout: 0s
insecure_skip_verify: false
s3forcepathstyle: true
chunk_store_config:
max_look_back_period: 0s
table_manager:
retention_deletes_enabled: false
retention_period: 0s
query_range:
align_queries_with_step: true
max_retries: 5
split_queries_by_interval: 15m
cache_results: true
results_cache:
cache:
enable_fifocache: true
fifocache:
max_size_items: 1024
validity: 24h
frontend_worker:
frontend_address: loki-distributed-query-frontend:9095
frontend:
log_queries_longer_than: 5s
compress_responses: true
tail_proxy_url: http://loki-distributed-querier:3100
compactor:
shared_store: s3
ruler:
storage:
type: local
local:
directory: /etc/loki/rules
ring:
kvstore:
store: memberlist
rule_path: /tmp/loki/scratch
alertmanager_url: http://alertmanager-main.system-monitoring:9093
Events: <none>
b0b
November 11, 2021, 2:05pm
3
Just following up. Looks like I got it working.
Solutions
make sure there are no / in the secret access key (seems to maybe be this issue )
final working aws.s3: config from this thread.
