Hi, I have been facing log drop issue in loki. Promtail running in k8s is supposed to push 600~700MB/s logs collectively. But after checking promtail metrics, it was evident log read size was always missed from log file total due to high log generation and log file rotation.
However if I horizontally scale and add too many distributors , log read rate of promtail would increase but that would be cost inefficient way.
The loki distributor outbound traffic sending streams to loki ingester drops to 117 MB/s (approx). Other multiple distributor boxes also drops to similar rate 117 MB/s after sometime.
If I restart the boxes, initially the traffic is random and high but after sometime it drops to 117 MB/s.
sometimes such logs are also seen after network drop for some time while all the ingesters were healthy though.
level=warn ts=2024-04-12T17:31:57.248428535Z caller=logging.go:123 traceID=5e4c2bb orgID=xyz msg="POST /loki/api/v1/push (500) 38.138881ms Response: "at least 2 live replicas required, could only find 1 - unhealthy instances: IP:9095\n" ws: false; Content-Length: 4585268; Content-Type: application/x-protobuf; User-Agent: promtail/2.9.2; X-Scope-Orgid: xyz; "
loki.conf (commonly working for all various --targets.)
# Loki Config
# (version=2.9.5, branch=release-2.9.x, revision=eee3598)
target: distributor
auth_enabled: true
http_prefix: ""
ballast_bytes: 0
use_buffered_logger: true
use_sync_logger: true
server:
http_listen_network: tcp
http_listen_address: ""
http_listen_port: 80
http_listen_conn_limit: 0
grpc_listen_network: tcp
grpc_listen_address: ""
grpc_listen_port: 9095
grpc_listen_conn_limit: 0
tls_cipher_suites: ""
tls_min_version: ""
http_tls_config:
cert_file: ""
key_file: ""
client_auth_type: ""
client_ca_file: ""
grpc_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: true
graceful_shutdown_timeout: 30s
http_server_read_timeout: 30m0s
http_server_write_timeout: 30m0s
http_server_idle_timeout: 2m0s
grpc_server_max_recv_msg_size: 1048576000
grpc_server_max_send_msg_size: 1048576000
grpc_server_max_concurrent_streams: 0
grpc_server_max_connection_idle: 2562047h47m16.854775807s
grpc_server_max_connection_age: 2562047h47m16.854775807s
grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
grpc_server_keepalive_time: 2h0m0s
grpc_server_keepalive_timeout: 20s
grpc_server_min_time_between_pings: 10s
grpc_server_ping_without_stream_allowed: true
log_format: logfmt
log_level: info
log_source_ips_enabled: false
log_source_ips_header: ""
log_source_ips_regex: ""
log_request_headers: false
log_request_at_info_level_enabled: false
log_request_exclude_headers_list: ""
http_path_prefix: ""
internal_server:
http_listen_address: localhost
http_listen_port: 3101
grpc_listen_network: ""
grpc_listen_port: 0
tls_min_version: ""
http_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
grpc_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: false
http_server_read_timeout: 30s
http_server_write_timeout: 30s
grpc_server_max_recv_msg_size: 0
grpc_server_max_send_msg_size: 0
grpc_server_max_connection_idle: 0s
grpc_server_max_connection_age: 0s
grpc_server_max_connection_age_grace: 0s
grpc_server_keepalive_time: 0s
grpc_server_keepalive_timeout: 0s
grpc_server_min_time_between_pings: 0s
grpc_server_ping_without_stream_allowed: false
log_format: ""
log_level: ""
enable: false
distributor:
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
host: localhost:8500
acl_token: ""
http_client_timeout: 20s
consistent_reads: false
watch_rate_limit: 0
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_insecure_skip_verify: false
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_enabled: false
mirror_timeout: 2s
heartbeat_period: 5s
heartbeat_timeout: 10s
instance_id:
instance_interface_names:
- ens5
- eth0
- en0
- lo
instance_port: 0
instance_addr: ""
instance_enable_ipv6: false
rate_store:
max_request_parallelism: 10000000
stream_rate_update_interval: 250ms
ingester_request_timeout: 30m0s
debug: true
write_failures_logging:
rate: 1MB
add_insights_label: true
querier:
tail_max_duration: 1h0m0s
query_ingesters_within: 3h0m0s
engine:
timeout: 5m0s
max_look_back_period: 30s
max_concurrent: 10
query_store_only: false
query_ingester_only: false
multi_tenant_queries_enabled: true
query_timeout: 0s
per_request_limits_enabled: false
query_scheduler:
max_outstanding_requests_per_tenant: 100
max_queue_hierarchy_levels: 3
querier_forget_delay: 0s
grpc_client_config:
grpc_compression: ""
rate_limit: 0
rate_limit_burst: 0
backoff_on_ratelimits: false
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
initial_stream_window_size: 63KiB1023B
initial_connection_window_size: 63KiB1023B
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
connect_backoff_base_delay: 1s
connect_backoff_max_delay: 5s
use_scheduler_ring: false
scheduler_ring:
kvstore:
store: consul
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
tokens_file_path: ""
zone_awareness_enabled: false
instance_id:
- ens5
- eth0
- en0
- lo
instance_port: 0
instance_addr: ""
instance_availability_zone: ""
frontend:
log_queries_longer_than: 0s
max_body_size: 10485760
query_stats_enabled: false
max_outstanding_per_tenant: 2048
scheduler_address: ""
scheduler_dns_lookup_period: 10s
scheduler_worker_concurrency: 5
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
graceful_shutdown_timeout: 5m0s
- ens5
- lo
address: ""
port: 0
compress_responses: false
downstream_url: ""
tail_proxy_url: ""
tail_tls_config:
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
query_range:
split_queries_by_interval: 0s
align_queries_with_step: true
results_cache:
cache:
enable_fifocache: false
default_validity: 1h0m0s
background:
writeback_goroutines: 10
writeback_buffer: 10000
writeback_size_limit: 1GB
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
update_interval: 1m0s
consistent_hash: true
circuit_breaker_consecutive_failures: 10
circuit_breaker_timeout: 10s
circuit_breaker_interval: 10s
redis:
endpoint:
master_name: ""
timeout: 500ms
expiration: 24h0m0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
route_randomly: false
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: frontend.
async_cache_write_back_concurrency: 16
async_cache_write_back_buffer_size: 500
compression: ""
cache_results: true
max_retries: 5
parallelise_shardable_queries: true
forward_headers_list: []
required_query_response_format: json
cache_index_stats_results: false
index_stats_results_cache:
cache:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint:
master_name: ""
timeout: 500ms
expiration: 24h0m0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: frontend.
compression: ""
ruler:
external_url: ""
datasource_uid: ""
ruler_client:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
evaluation_interval: 1m0s
poll_interval: 1m0s
storage:
type: local
azure:
environment: AzureGlobal
account_name: ""
account_key: ""
container_name: loki
endpoint_suffix: ""
use_managed_identity: false
use_federated_token: false
user_assigned_id: ""
use_service_principal: false
client_id: ""
client_secret: ""
tenant_id: ""
chunk_delimiter: '-'
download_buffer_size: 512000
upload_buffer_size: 256000
upload_buffer_count: 1
request_timeout: 30s
max_retries: 5
min_retry_delay: 10ms
max_retry_delay: 500ms
alibabacloud:
bucket: ""
endpoint: ""
access_key_id: ""
secret_access_key: ""
gcs:
bucket_name: ""
service_account: ""
chunk_buffer_size: 0
request_timeout: 0s
enable_opencensus: true
enable_http2: true
s3:
s3: ""
s3forcepathstyle: false
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
session_token: ""
insecure: false
sse_encryption: false
http_config:
timeout: 0s
idle_conn_timeout: 1m30s
response_header_timeout: 0s
ca_file: ""
signature_version: v4
storage_class: STANDARD
sse:
type: ""
kms_key_id: ""
kms_encryption_context: ""
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
bos:
bucket_name: ""
endpoint: bj.bcebos.com
access_key_id: ""
swift:
auth_version: 0
auth_url: ""
internal: false
username: ""
user_domain_name: ""
user_domain_id: ""
user_id: ""
password: ""
domain_id: ""
domain_name: ""
project_id: ""
project_name: ""
project_domain_id: ""
project_domain_name: ""
region_name: ""
container_name: ""
max_retries: 3
connect_timeout: 10s
request_timeout: 5s
cos:
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
http_config:
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
api_key: ""
service_instance_id: ""
auth_endpoint: https://iam.cloud.ibm.com/identity/token
cr_token_file_path: ""
trusted_profile_name: ""
trusted_profile_id: ""
local:
directory: /etc/loki/rules
rule_path: /etc/loki/temp-rules-storage
alertmanager_url: http://:9093
enable_alertmanager_discovery: false
alertmanager_refresh_interval: 1m0s
enable_alertmanager_v2: false
notification_queue_capacity: 10000
notification_timeout: 10s
alertmanager_client:
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
basic_auth_username: ""
basic_auth_password: ""
type: Bearer
for_outage_tolerance: 1h0m0s
for_grace_period: 10m0s
resend_delay: 1m0s
enable_sharding: true
sharding_strategy: default
sharding_algo: by-group
search_pending_for: 5m0s
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
instance_id:
- ens5
- eth0
- en0
- lo
instance_port: 0
instance_addr: ""
num_tokens: 128
flush_period: 1m0s
enable_api: true
enabled_tenants: ""
disabled_tenants: ""
disable_rule_group_label: false
wal:
tenant: ""
remotewrite: []
dir: ruler-wal
truncate_frequency: 1h0m0s
min_age: 5m0s
max_age: 4h0m0s
wal_cleaner:
min_age: 12h0m0s
deprecatedperiod: 0s
remote_write:
enabled: false
config_refresh_period: 10s
evaluation:
mode: local
max_jitter: 0s
ingester_client:
pool_config:
client_cleanup_period: 15s
health_check_ingesters: true
remote_timeout: 5m0s
remote_timeout: 15m0s
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
ingester:
lifecycler:
ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
http_client_timeout: 1m0s
watch_rate_limit: 0
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
replication_factor: 2
excluded_zones: ""
num_tokens: 128
heartbeat_timeout: 1m0s
observe_period: 0s
join_after: 0s
min_ready_duration: 15s
interface_names:
- ens5
- eth0
- en0
- lo
enable_inet6: false
final_sleep: 0s
unregister_on_shutdown: true
readiness_check_ring_health: true
address: ""
port: 0
id:
concurrent_flushes: 128
flush_check_period: 30s
flush_op_timeout: 10m0s
chunk_retain_period: 0s
chunk_idle_period: 15m0s
chunk_block_size: 262144
chunk_target_size: 2621440
chunk_encoding: snappy
max_chunk_age: 30m0s
autoforget_unhealthy: true
sync_period: 0s
sync_min_utilization: 0
max_returned_stream_errors: 10
query_store_max_look_back_period: 0s
wal:
enabled: true
dir: /data
checkpoint_duration: 5m0s
flush_on_shutdown: true
replay_memory_ceiling: 4GB
index_shards: 32
max_dropped_streams: 10
shutdown_marker_path: ""
index_gateway:
mode: simple
ring:
kvstore:
store: consul
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
instance_id:
- ens5
- eth0
- en0
- lo
instance_port: 0
instance_addr: ""
replication_factor: 3
storage_config:
alibabacloud:
bucket: ""
endpoint: ""
access_key_id: ""
aws:
dynamodb:
dynamodb_url: ""
api_limit: 2
throttle_limit: 10
metrics:
url: ""
target_queue_length: 100000
scale_up_factor: 1.3
ignore_throttle_below: 1
queue_length_query: sum(avg_over_time(cortex_ingester_flush_queue_length{job="cortex/ingester"}[2m]))
write_throttle_query: sum(rate(cortex_dynamo_throttled_total{operation="DynamoDB.BatchWriteItem"}[1m]))
by (table) > 0
write_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation="DynamoDB.BatchWriteItem"}[15m]))
by (table) > 0
read_usage_query: sum(rate(cortex_dynamo_consumed_capacity_total{operation="DynamoDB.QueryPages"}[1h]))
by (table) > 0
read_error_query: sum(increase(cortex_dynamo_failures_total{operation="DynamoDB.QueryPages",error="ProvisionedThroughputExceededException"}[1m]))
by (table) > 0
chunk_gang_size: 10
chunk_get_max_parallelism: 32
backoff_config:
min_period: 100ms
max_period: 50s
max_retries: 20
kms_key_id: ""
s3: s3://ap-south-1/loki-paipush-prod
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
session_token: ""
insecure: false
http_config:
timeout: 0s
ca_file: ""
sse:
type: ""
kms_key_id: ""
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
azure:
account_name: ""
account_key: ""
endpoint_suffix: ""
client_id: ""
client_secret: ""
tenant_id: ""
max_retries: 5
bos:
bucket_name: ""
access_key_id: ""
bigtable:
project: ""
instance: ""
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: true
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
table_cache_enabled: true
table_cache_expiration: 30m0s
gcs:
bucket_name: ""
service_account: ""
request_timeout: 0s
enable_http2: true
cassandra:
addresses: ""
port: 9042
keyspace: ""
consistency: QUORUM
disable_initial_host_lookup: false
SSL: false
host_verification: true
host_selection_policy: round-robin
CA_path: ""
tls_cert_path: ""
tls_key_path: ""
auth: false
username: ""
password: ""
password_file: ""
custom_authenticators: []
timeout: 2s
connect_timeout: 5s
reconnect_interval: 1s
max_retries: 0
retry_max_backoff: 10s
retry_min_backoff: 100ms
query_concurrency: 0
num_connections: 2
convict_hosts_on_failure: true
table_options: ""
boltdb:
directory: ""
filesystem:
directory: ""
swift:
auth_version: 0
auth_url: ""
internal: false
username: ""
user_domain_id: ""
user_id: ""
password: ""
domain_id: ""
domain_name: ""
project_id: ""
project_name: ""
region_name: ""
container_name: ""
max_retries: 3
request_timeout: 5s
grpc_store: {}
hedging:
at: 0s
up_to: 2
max_per_second: 5
named_stores:
aws: {}
azure: {}
bos: {}
filesystem: {}
gcs: {}
alibabacloud: {}
swift: {}
cos: {}
cos:
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
http_config:
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
api_key: ""
index_cache_validity: 5m0s
index_queries_cache_config:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: store.index-cache-read.
disable_broad_index_queries: false
max_parallel_get_chunk: 150
max_chunk_batch_size: 50
boltdb_shipper:
active_index_directory: ""
shared_store: ""
shared_store_key_prefix: index/
cache_location: ""
cache_ttl: 24h0m0s
resync_interval: 5m0s
query_ready_num_days: 0
index_gateway_client:
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
log_gateway_requests: false
use_boltdb_shipper_as_backup: false
ingestername: ""
mode: RW
ingesterdbretainperiod: 0s
build_per_tenant_index: false
tsdb_shipper:
active_index_directory: /data/tsdb-index
shared_store: aws
cache_location: /data/tsdb-cache
cache_ttl: 24h0m0s
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
server_address: loki-index-gateway:9095
ingestername: ""
mode: RW
enable_postings_cache: false
chunk_store_config:
chunk_cache_config:
enable_fifocache: true
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: store.chunks-cache.
chunk_cache_config_l2:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: experimental.store.chunks-cache-l2.
write_dedupe_cache_config:
background:
memcached:
expiration: 0s
batch_size: 1024
parallelism: 100
memcached_client:
host: ""
service: memcached
addresses: ""
timeout: 100ms
max_idle_conns: 16
max_item_size: 0
redis:
endpoint: ""
master_name: ""
timeout: 500ms
expiration: 0s
db: 0
pool_size: 0
username: ""
password: ""
tls_enabled: false
idle_timeout: 0s
embedded_cache:
max_size_mb: 100
ttl: 1h0m0s
fifocache:
max_size_bytes: 1GB
max_size_items: 0
ttl: 1h0m0s
validity: 0s
purgeinterval: 0s
prefix: store.index-cache-write.
l2_chunk_cache_handoff: 0s
cache_lookups_older_than: 0s
schema_config:
configs:
store: tsdb
object_store: aws
schema: v12
index:
prefix: index_
period: 1d
tags: {}
chunks:
prefix: ""
period: 0s
tags: {}
row_shards: 16
compactor:
working_directory: /data/loki/tsdb-shipper-compactor
shared_store: aws
compaction_interval: 10m0s
apply_retention_interval: 0s
retention_enabled: false
retention_delete_delay: 2h0m0s
retention_delete_worker_count: 150
retention_table_timeout: 0s
delete_request_store: ""
delete_batch_size: 70
delete_request_cancel_period: 24h0m0s
delete_max_interval: 0s
max_compaction_parallelism: 1
upload_parallelism: 10
compactor_ring:
kvstore:
store: memberlist
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
instance_id:
- ens5
- eth0
- en0
- lo
instance_port: 0
instance_addr: ""
_: false
tables_to_compact: 0
skip_latest_n_tables: 0
deletion_mode: ""
compactor_grpc_client:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
limits_config:
ingestion_rate_strategy: local
ingestion_rate_mb: 100000
ingestion_burst_size_mb: 100000
max_label_name_length: 1024
max_label_value_length: 2048
max_label_names_per_series: 30
reject_old_samples: true
reject_old_samples_max_age: 1d
creation_grace_period: 10m
enforce_metric_name: false
max_line_size: 0B
max_line_size_truncate: false
increment_duplicate_timestamp: false
max_streams_per_user: 0
max_global_streams_per_user: 0
unordered_writes: true
per_stream_rate_limit: 100000MB
per_stream_rate_limit_burst: 1000000MB
max_chunks_per_query: 20000000
max_query_series: 10000
max_query_lookback: 0s
max_query_length: 7d2h
max_query_range: 0s
max_query_parallelism: 32
tsdb_max_query_parallelism: 512
tsdb_max_bytes_per_shard: 600MB
cardinality_limit: 100000
max_streams_matchers_per_query: 100000
max_concurrent_tail_requests: 100
max_entries_limit_per_query: 100000
max_cache_freshness_per_query: 15m
max_stats_cache_freshness: 0s
max_queriers_per_tenant: 0
query_ready_index_num_days: 0
query_timeout: 15m
split_queries_by_interval: 5m
min_sharding_lookback: 0s
max_query_bytes_read: 0B
max_querier_bytes_read: 0B
volume_enabled: false
volume_max_series: 1000
ruler_evaluation_delay_duration: 0s
ruler_max_rules_per_rule_group: 0
ruler_max_rule_groups_per_tenant: 0
ruler_alertmanager_config: null
ruler_tenant_shard_size: 0
ruler_remote_write_disabled: false
ruler_remote_write_url: ""
ruler_remote_write_timeout: 0s
ruler_remote_write_headers: {}
ruler_remote_write_queue_capacity: 0
ruler_remote_write_queue_min_shards: 0
ruler_remote_write_queue_max_shards: 0
ruler_remote_write_queue_max_samples_per_send: 0
ruler_remote_write_queue_batch_send_deadline: 0s
ruler_remote_write_queue_min_backoff: 0s
ruler_remote_write_queue_max_backoff: 0s
ruler_remote_write_queue_retry_on_ratelimit: false
ruler_remote_write_sigv4_config: null
ruler_remote_evaluation_timeout: 0s
ruler_remote_evaluation_max_response_size: 0
deletion_mode: filter-and-delete
retention_period: 10d
per_tenant_override_config: ""
per_tenant_override_period: 10s
allow_deletes: false
shard_streams:
enabled: false
logging_enabled: false
desired_rate: 3MB
index_gateway_shard_size: 0
frontend_worker:
frontend_address: loki-querier-fe:9095
dns_lookup_duration: 3s
parallelism: 50
match_max_concurrent: true
grpc_client_config:
rate_limit: 0
rate_limit_burst: 0
backoff_config:
min_period: 100ms
max_period: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
connect_timeout: 5s
table_manager:
throughput_updates_disabled: false
retention_deletes_enabled: false
retention_period: 0s
poll_interval: 2m0s
creation_grace_period: 10m0s
index_tables_provisioning:
enable_ondemand_throughput_mode: false
provisioned_write_throughput: 1000
provisioned_read_throughput: 300
write_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
read_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
enable_inactive_throughput_on_demand_mode: false
inactive_write_throughput: 1
inactive_read_throughput: 300
inactive_write_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
inactive_read_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
inactive_write_scale_lastn: 4
inactive_read_scale_lastn: 4
chunk_tables_provisioning:
write_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
read_scale:
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
enabled: false
role_arn: ""
min_capacity: 3000
max_capacity: 6000
out_cooldown: 1800
in_cooldown: 1800
target: 80
memberlist:
node_name: ""
randomize_node_name: true
stream_timeout: 10s
retransmit_factor: 4
pull_push_interval: 30s
gossip_interval: 200ms
gossip_nodes: 3
gossip_to_dead_nodes_time: 30s
dead_node_reclaim_time: 0s
compression_enabled: true
advertise_addr: ""
advertise_port: 7946
cluster_label: ""
cluster_label_verification_disabled: false
join_members:
- loki-memberlist.com
min_join_backoff: 1s
max_join_backoff: 1m0s
max_join_retries: 10
abort_if_cluster_join_fails: false
rejoin_interval: 0s
left_ingesters_timeout: 5m0s
leave_timeout: 20s
message_history_buffer_bytes: 0
bind_addr: []
bind_port: 7946
packet_dial_timeout: 2s
packet_write_timeout: 5s
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
runtime_config:
period: 10s
file: ""
tracing:
enabled: true
analytics:
reporting_enabled: false
usage_stats_url: https://stats.grafana.org/loki-usage-report
legacy_read_target: true
common:
path_prefix: ""
storage:
s3:
s3: ""
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
session_token: ""
insecure: false
http_config:
timeout: 0s
ca_file: ""
sse:
type: ""
kms_key_id: ""
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
gcs:
bucket_name: ""
service_account: ""
request_timeout: 0s
enable_http2: true
azure:
account_name: ""
account_key: ""
endpoint_suffix: ""
client_id: ""
client_secret: ""
tenant_id: ""
max_retries: 5
alibabacloud:
bucket: ""
endpoint: ""
access_key_id: ""
bos:
bucket_name: ""
access_key_id: ""
swift:
auth_version: 0
auth_url: ""
internal: false
username: ""
user_domain_id: ""
user_id: ""
password: ""
domain_id: ""
domain_name: ""
project_id: ""
project_name: ""
region_name: ""
container_name: ""
max_retries: 3
request_timeout: 5s
filesystem:
chunks_directory: ""
rules_directory: ""
hedging:
at: 0s
up_to: 2
max_per_second: 5
cos:
bucketnames: ""
endpoint: ""
region: ""
access_key_id: ""
http_config:
backoff_config:
min_period: 100ms
max_period: 3s
max_retries: 5
api_key: ""
persist_tokens: false
ring:
kvstore:
store: consul
prefix: collectors/
consul:
acl_token: ""
watch_rate_limit: 1
watch_burst_size: 1
cas_retry_delay: 1s
etcd:
endpoints: []
dial_timeout: 10s
max_retries: 10
tls_enabled: false
tls_cert_path: ""
tls_key_path: ""
tls_ca_path: ""
tls_server_name: ""
tls_min_version: ""
username: ""
password: ""
multi:
primary: ""
secondary: ""
mirror_timeout: 2s
instance_id:
- ens5
- eth0
- en0
- lo
instance_port: 0
instance_addr: ""
- ens5
instance_addr: ""
compactor_address: http://loki-compactor
compactor_grpc_address: ""
