I am using promtail to push logs from several bare metal servers to Loki, and I do filtering in Loki, for instance: {job="ubuntu_server01_varlogs"} |~ "[Ee]rror" !~"Read_Error_Rate" !~"ubuntu-advantage-timer" ...
However, now Loki has repeatedly become overwhelmed with logs: 2021-12-03 09:55:33 Dec 3 09:55:32 server01 promtail-linux-amd64[2205]: level=warn ts=2021-12-03T08:55:32.480069794Z caller=client.go:344 component=client host=10.0.0.21:3100 msg="error sending batch, will retry" status=429 error="server returned HTTP status 429 Too Many Requests (429): Ingestion rate limit exceeded (limit: 4194304 bytes/sec) while attempting to ingest '8055' lines totaling '1048458' bytes, reduce log volume or contact your Loki administrator to see if the limit can be increased"
Perhaps it is better to filter out unwanted messages in promtail before pushing them to Loki? If so, how do I filter based on the log message content? My promtail config-file looks like this right now:
just out of curiosity, what sort of log volumes do you see? I was doing load tests and had no problems ingesting close to 10k logs per second with just one distributor and one indexer node. I’m using “micro services mode” with S3 storage…
I also saw some 429 errors at the very start. Promtail replays all log files it finds so initially there will be a flood of messages. Not sure if you can configure it to start from the tail of log files and only ship new lines.
Looked at rates and this problem occurs at server startup. Up to around 16k/sec. This is a bare-metal installation both on clients and on the machine running Loki and Grafana, so there is perhaps less leeway in terms of capacity?
This filters out everything that doesn’t contain "rror", and everything containing “ubuntu-advantage-timer”. Will have to work on the filter to include things containing critical, bug, fail, etc, but at least I got it working.
