Hi
I am using Promtail to analyse an heterogeneous log file made more or less like this:
SELL O -- 16000101 00:00:00.00 UTC save: 20240503 14:08:33.83 87
SELL P -- 16000101 00:00:00.00 UTC save: 20240503 14:08:33.83 87
SELL R -- 16000101 00:00:00.00 UTC save: 20240503 14:08:33.83 87
SELL E -- 16000101 00:00:00.00 UTC save: 20240503 14:08:33.83 87
SPS2 F IV -- 16000101 00:00:00.00 UTC save: 20240503 14:08:33.83 87
SPS2 H -- 16000101 00:00:00.00 UTC save: 20240503 14:08:33.83 87
WARNING: 864570_2 SCIAR G -- was requested multiple or was not found.
WARNING: 864570_2 SCIAR H -- multiplication was requested or was not found.
WARNING: 864570_2 SCIAR L -- was requested multiple or was not found.
WARNING: 864570_2 SCIAR T -- was requested in multiplication mode, or was not found.
SPS2 F IV -- 16000101 00:00:00 UTC save: 20240503 14:08:33.83 87
WARNING: 864570_2 SCIAR H -- a multiplication was requested or was not found
MATCH FOUND 20240503 13:00:30.61
SALE O -- 16000101 00:00:00.00 UTC save: 20240503 14:08:33.83 87
I created a Promtail configuration file:
server:
http_listen_port: 9080
grpc_listen_port: 0
log_level: debug
positions:
filename: /tmp/positions.yaml
clients:
- url: http://host:3100/loki/api/v1/push
scrape_configs:
- job_name: server1
static_configs:
- obiettivi:
- localhost
etichette:
job: server1
__path__: /var/logs/server1/mytest.log
pipeline_stages:
- match:
selettore: '{job="server1"} |= "MATCH"'
stages:
- regex:
expression: ‘^MATCH FOUND\s+(?P<time>\d{8}\s+\d{2}:\d{2}:\d{2}\.\d{2})'
- timestamp:
format: "20060102 15:04:05.99"
source: time
- drop:
older_than: 3h
drop_counter_reason: "line_too_old"
The problem is that in Loki, running the query {job="server1"}, I see the whole log lines and not only the lines that contain MATCH string; and this is useless for me and takes up an unnecessary disk space.
Is there any way to store only the necessary log lines in Loki? Something like a simple grep performed by Promtail.
Thank you.
