Hello Community,
I have a log file with a lot of entries, one entry per line, 14 fields per entry, fields separated by semicolons. I want to “prettify” some of the entries before they are sent to Loki and then on to Grafana. Here is the relevant part of the log file including the entry where I want the “replace” stage to replace some XML-like tags with dashes:
26.12.23. 13:01:58 ;26.12.23. 13:00:35 ;ON ;LogOnly ;1170 POSN failure ;secondary sensor failed Gps1 ;secondary sensor failed Gps1 ;5025111736321_G19_O171 ;CAUTION ; ;CATEGORY B;3016;847;7
26.12.23. 13:02:05 ;26.12.23. 13:00:32 ;OFF ;Valid ;10549 HCS unavailable ;No gyro input ;**<R><A><T>3</T><N>OrigStation_NR</N><V>739</V></A><A><T>4</T><N>EventType_NR</N><V>0</V></A><A><T>10</T><N>Id</N><V>1605E3020000470363029A0200000000000000000000</V></A></R>**;AutopilotUNAVAILABLE ;CAUTION ;nav/5058 ;CATEGORY B;0;0;6
26.12.23. 13:02:06 ;26.12.23. 13:00:30 ;OFF ;LogOnly ;1171 HDG failure ;secondary sensor failed Gyro1 ;secondary sensor failed Gyro1 ;5029406703617_G19_O178 ;CAUTION ; ;CATEGORY B;3016;852;7
Extract from my promtail configuration file:
scrape_configs:
- job_name: alarms
static_configs:
- targets:
- localhost
labels:
job: Alarm_logs
__path__: 'C:\\Logging\\Alarm1.log'
pipeline_stages:
- regex:
expression: '(?s);(?P<ExtendedInfo><[^;]+>);'
- labels:
ExtendedInfo:
- replace:
expression: '(<([^;]*?)>)'
source: ExtendedInfo
replace: '-'
Here is how the replace stage looks like when promtail is run with the --inspect argument:
[inspect: regex stage]:
{stages.Entry}.Extracted["ExtendedInfo"]:
+: <R><A><T>3</T><N>OrigStation_NR</N><V>739</V></A><A><T>4</T><N>EventType_NR</N><V>0</V></A><A><T>10</T><N>Id</N><V>1605E3020000470363029A0200000000000000000000</V></A></R>
[inspect: replace stage]:
{stages.Entry}.Extracted["ExtendedInfo"].(string):
-: <R><A><T>3</T><N>OrigStation_NR</N><V>739</V></A><A><T>4</T><N>EventType_NR</N><V>0</V></A><A><T>10</T><N>Id</N><V>1605E3020000470363029A0200000000000000000000</V></A></R>
+: ---3--OrigStation_NR--739----4--EventType_NR--0----10--Id--1605E3020000470363029A0200000000000000000000---
And here is what that log entry looks like in Grafana Explore:
To sum things up:
- promtail run with --inspect argument shows that replacement takes place
- the log entry appears in its original form (without replacement) in Grafana.
What am I missing? Any clues will be greatly appreciated!
