Here is what my promtail configuration looks like:
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
client:
url: http://localhost:3100/loki/api/v1/push
scrape_configs:
- job_name: system
pipeline_stages:
- match:
selector: '{name="promtail"}'
stages:
- regex:
expression: '(?P<ip>^[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}).*(?P<datetime>[0-9]{2}\/[a-zA-Z]{3}\/[0-9]{1,4}:[0-9]{2}:[0-9]{2}:[0-9]{2}).*(?P<method>DELETE|PUT|POST|GET).*(?P<endpoint>usr/[a-z]*/[a-z]*|usr/[a-z]*|usr).*(?P<status> [0-9]{3}).*(?P<response_bytes> [0-9]{4} ).*(?P<user_agent>"(.*?)").*(?P<response_time> [0-9]{2,4})'
- labels:
ip:
method:
endpoint:
status:
response_bytes:
user_agent:
response_time:
- timestamp:
format: 27/Dec/2037:12:00:00
source: datetime
static_configs:
- targets:
- localhost
labels:
job: varlogs
host: yourhost
__path__: C:\Users\umutc\Desktop\denme.log
Here is what Logs in grafana looks like:
As you see, none of the labels which promtail would put seems. what is the problem?
