Issue with regex pattern in scrape config for Grafana Loki and Promtail configuration deployed on K8S
Hi Team,
I am trying to add regex pattern to filter log and add labels by using Regex pattern in Scrape config of loki and promtail config as mentioned below
promtail:
enabled: true
config:
serverPort: 3101
clients:
  • url: http://{{ .Release.Name }}:3100/loki/api/v1/push
    log_level: debug
    snippets:
    scrapeConfigs: |
    - job_name: myapp-logs
    static_configs:
    - targets:
    - {{ .Release.Name }}
    labels:
    job: myapp-logs
    path: /usr/local/tomcat/logsMT/myapp.log
    pipeline_stages:
    - regex:
    expression: “(?P\d{4}-\d{2}-\d{2} \d{2}:\d{2}:\d{2}) (?P\w+) (?P[^:]+):(?P[^\s]+) (?P\w+) (?P[^\s]+) Parameter:{(?P[^\}]+)} Status:(?P\d+) ExecutionTime:(?P[^\s]+)”
    - labels:
    level: level
    appname: appname
    appmodule: appmodule
    method: method
    endpoint: endpoint
    status: status
    - output:
    source: stdout
After deploying above configuration I am getting below error
"level=warn ts=2024-06-24T07:31:20.23667182Z caller=logging.go:123 msg="GET /ready (500) 156.257µs Response: “Not ready: Unable to find any logs to tail. Please verify permissions, volumes, scrape_config, etc.\n” ws: false; Accept: /; Connection: close; User-Agent: kube-probe/1.26;
However I am getting all the logs if I do not apply any regex pattern.
If you are collecting logs from a path, your target should be localhost, no?
yes I tried with localhost as well but still error is same.
Do you see any error log?
Also, try enable debugging and inspection mode and test your config on some sample logs and see what it says (see Troubleshooting Promtail | Grafana Loki documentation)
I am trying now without regex but still I am not getting any log from application
Below are my configurations
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /var/log/positions.yaml
clients:
- url: http://grafana-loki-umatch:3100/loki/api/v1/push
scrape_configs:
- job_name: system
static_configs:
- targets:
- localhost
labels:
job: varlogs
path: /var/log/*log
- targets:
- localhost
labels:
job: sonarqube_logs
path: /opt/sonarqube/logs/*log
  1. Did you try the debug option?
  2. What are you seeing in your promtail logs?
