Hi there,
I’m using promtail 2.9.7 and I have a specific use case with promtail. I want to send only the ERROR log. so I came up with this pattern to match the other log and drop it ^(?!.*ERROR).*
You can test it by yourself, it only matches any other line but ERROR.
this is my promtail configuration
scrape_configs:
- job_name: system
static_configs:
- targets:
- localhost
labels:
job: application
__path__: /var/log/gitlab/gitlab-rails/application_json.log
pipeline_stages:
- drop:
expression: "^(?!.*ERROR).*"
after I restarted the service, I got many of these errors referring to the drop section
invalid drop stage config: drop stage regex compilation error: error parsing regexp: invalid or unsupported Perl syntax: `(?!`"
Does this happen because promtail can’t understand the regex pattern? if so, how should I change it so promtail can understand?
Thanks
