Fresh to loki, thanks ahead.
Deployments
I deploy a loki cluster by seperating the components into different pods:
- distributor * 3
- ingester * 3
- custom-loki-client * 2
Config
common
auth_enabled: false
http_prefix:
common:
path_prefix: /data/loki
replication_factor: 1
ring:
kvstore:
store: memberlist
server:
http_listen_address: 0.0.0.0
grpc_listen_address: 0.0.0.0
grpc_server_max_recv_msg_size: 41943040
grpc_server_max_send_msg_size: 41943040
http_listen_port: 3100
grpc_listen_port: 9095
log_level: info
ingester:
lifecycler:
join_after: 10s
observe_period: 5s
wal:
enabled: true
dir: /data/loki/wal
flush_on_shutdown: true
max_chunk_age: 1h
chunk_retain_period: 30s
chunk_encoding: snappy
chunk_target_size: 0
chunk_block_size: 104857600
memberlist:
join_members: ["${RING_DOMAIN:-127.0.0.1}"] # same ENV setting over ingester and distributer
dead_node_reclaim_time: 30s
gossip_to_dead_nodes_time: 15s
left_ingesters_timeout: 30s
bind_addr: ['0.0.0.0']
bind_port: 7946
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
limits_config:
ingestion_rate_strategy: local
ingestion_rate_mb: 1024
ingestion_burst_size_mb: 2048
per_stream_rate_limit: 1024MB
per_stream_rate_limit_burst: 2048MB
max_global_streams_per_user: 0
storage_config:
boltdb_shipper:
shared_store: filesystem
shared_store_key_prefix: index/
active_index_directory: /data/loki/boltdb-shipper-active
cache_location: /data/loki/boltdb-shipper-cache
filesystem:
directory: /dataceph/loki/chunks
table_manager:
retention_deletes_enabled: true
retention_period: 48h
distributor
target: distributor
<config-common>
ingester
target: ingester
<config-common>
Ring Status
Seems the tokens ownership is balanced among all ingester instances.
Issue Description
In summary, there is equitable of netflow among distributor, but there exists an imbalance among ingester.
Upon closer examination using itop, It is apparent that the imbalanced netflow originates from various distributors and converges towards a solitary ingester through port 9095.
Please give me some advice, thanks again.
