hello,
I am using Loki-distributed on EKS.
this is version information
- chart-version: 0.43.0 / loki-version: 2.4.2
I know distributor do load balancing to log ingestion.
but, actually distributor does not load balancing in my cluster.
I have 9 ingester pod. and “replication_factor” is “1”.
there is only one pod do working. other 8 pod is idle.
if I change to “replication_factor” to “2”
two pod will work, other 7 pod is idle.
I think this is very very big problem.
if this problem is not fixing, I can’t use Loki
could you help me please?
this is my configuration.
auth_enabled: false
chunk_store_config:
chunk_cache_config:
enable_fifocache: true
fifocache:
max_size_bytes: 512MB
max_look_back_period: 300s
compactor:
shared_store: filesystem
distributor:
ring:
kvstore:
store: memberlist
frontend:
compress_responses: true
log_queries_longer_than: 1m
max_outstanding_per_tenant: 4096
tail_proxy_url: http://loki-querier:3100
frontend_worker:
frontend_address: loki-query-frontend:9095
grpc_client_config:
max_recv_msg_size: 1048576000
max_send_msg_size: 1048576000
match_max_concurrent: false
parallelism: 8
ingester:
chunk_block_size: 1536000
chunk_encoding: snappy
chunk_idle_period: 30m
chunk_retain_period: 1m
chunk_target_size: 1536000
lifecycler:
join_after: 0s
ring:
kvstore:
store: memberlist
replication_factor: 1
max_chunk_age: 1h
max_transfer_retries: 0
wal:
dir: /var/loki/wal
limits_config:
enforce_metric_name: false
ingestion_burst_size_mb: 100
ingestion_rate_mb: 100
max_cache_freshness_per_query: 10m
max_entries_limit_per_query: 10000
max_global_streams_per_user: 0
max_query_length: 720h
max_streams_per_user: 0
per_stream_rate_limit: 30MB
per_stream_rate_limit_burst: 50MB
reject_old_samples: true
memberlist:
join_members:
- loki-memberlist
querier:
engine:
timeout: 5m
max_concurrent: 2048
query_ingesters_within: 1h
query_timeout: 5m
query_range:
align_queries_with_step: true
cache_results: false
max_retries: 5
parallelise_shardable_queries: true
results_cache:
cache:
fifocache:
max_size_bytes: 1GB
split_queries_by_interval: 10m
ruler:
alertmanager_url: http://alertmanager:9093
enable_api: true
rule_path: /tmp/loki/scratch
storage:
s3:
s3: s3://ap-northeast-2/{{ rule_bucket_name }}
type: s3
schema_config:
configs:
index:
period: 720h
prefix: {{ index_name }}_
object_store: s3
schema: v11
store: aws
server:
grpc_server_max_recv_msg_size: 1048576000
grpc_server_max_send_msg_size: 1048576000
grpc_server_min_time_between_pings: 10s
grpc_server_ping_without_stream_allowed: true
http_listen_port: 3100
http_server_idle_timeout: 300s
http_server_write_timeout: 60s
storage_config:
aws:
dynamodb:
dynamodb_url: dynamodb://ap-northeast-2
http_config:
response_header_timeout: 5s
s3: s3://ap-northeast-2/{{ bucket_name }}
boltdb_shipper:
active_index_directory: /var/loki/index
cache_location: /var/loki/cache
cache_ttl: 1h
index_gateway_client:
server_address: dns://loki-index-gateway:9095
shared_store: s3
index_cache_validity: 1h
index_queries_cache_config:
fifocache:
table_manager:
chunk_tables_provisioning:
enable_inactive_throughput_on_demand_mode: true
enable_ondemand_throughput_mode: true
inactive_read_throughput: 0
inactive_write_throughput: 0
provisioned_read_throughput: 0
provisioned_write_throughput: 0
index_tables_provisioning:
retention_deletes_enabled: false
retention_period: 0
throughput_updates_disabled: false
