login.OAuthLogin(missing saved state) ans some times login.oauthlogin(get info from generic_oauth), OAuth sign in with keycloak
    7.5.7 and i tried in both linux and windows OS
    grafana sso with keycloak
    keycloak.ini / grafana.ini
  • What happened?
    After keycloak authentication throwing error
    it should redirect to the grafana homepage
    yes
This is a frequently asked question. I would recommend to read older topics about this issue: Search results for 'missing saved state' - Grafana Labs Community Forums
Thank you i got the solution
Can I kindly ask you what you what was the solution?
i have the same problem can u please tell me what was your solution
