Grafana OAuth Authentication - missing saved state
i have a issue with login via OAuth authentication. I am new in this authentication method.
I have iframe where is panel:
<iframe src="http://192.168.11.100:83/grafana/d-solo/XKWwL-xWk/elinew-dashboard?orgId=1&from=1558773975611&to=1574675175611&theme=light&panelId=4" class="embed-responsive" height="500" frameborder="0"></iframe>
it’s look like this:
I follow this guide: Configure generic OAuth2 authentication | Grafana documentation and set aplication on: https://manage.auth0.com/ where i set name and Allowed Callback URLs: http://192.168.11.100:83/login/generic_oauth.
Then i follow this: https://github.com/nbayramberdiyev/grafana-generic-oauth, my grafana.ini look like:
[auth.generic_oauth]
name = OAuth
enabled = true
allow_sign_up = false
client_id = i copy client_id from oauth
client_secret = i copy client_secret from oauth
scopes = user:email,read:org
email_attribute_name = email:primary
email_attribute_path =
auth_url = http://192.168.11.100/lzatloukal/grafana-generic-oauth/src/oauth/auth.php
token_url = http://192.168.11.100/lzatloukal/grafana-generic-oauth/src/oauth/token.php
api_url = http://192.168.11.100/lzatloukal/grafana-generic-oauth/src/oaut/user.php
team_ids =
allowed_organizations =
tls_skip_verify_insecure = false
tls_client_cert =
tls_client_key =
tls_client_ca =
send_client_credentials_via_post = false
After i click on Sign in with OAuth button i am redirected on this error:
My grafana.log looks like:
t=2019-11-29T13:54:21+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/d-solo/XKWwL-xWk/elinew-dashboard status=302 remote_addr=192.168.11.21 time_ms=0 size=37 referer=http://192.168.11.100/lzatloukal/test.html
t=2019-11-29T13:54:22+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=302 remote_addr=192.168.11.21 time_ms=0 size=360 referer=http://192.168.11.100:83/grafana/login
t=2019-11-29T13:54:22+0100 lvl=eror msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=500 remote_addr=192.168.11.21 time_ms=0 size=1750 referer=http://192.168.11.100:83/grafana/login
Somebody please help me? Thank you.
I tried setting cookie_samesite = lax and that fixed it for me
What did you do to solve this problem? the cookie_samesite = lax didn’t work to me. Is there any other way?
