I want to expand the log lines in the Log Panel like in the Explore feature.
In the Explore tab, you can click on a log line and it gets expanded. Then you have access to all the fields of the elasticsearch entry:
But the Log Panel only shows the lines:
I had to reorder the fields with the Transform settings, so the message is the first field after the timestamp. The panel only shows one field.
Is there any possibility to make the panel lieke the explorer?
Kind regards,
seism0saurus
