Hi folks, I’m trying to use the alpha logs panel introduced in 6.4.0-beta1 to look at logs from an Elasticsearch data source, but am struggling to get it working, has this combination been tested, or is the logs panel strictly Loki at the moment?
Just updated 6.4.1 and tried using as tables broke in update. Seems this indeed doesn’t work and neither does tables
It seems it will be fixed with 6.4.2 …
see : https://github.com/grafana/grafana/issues/19531
I think this is the following issue: https://github.com/grafana/grafana/issues/19789
I think it’s related to the Log Panel.
Try to use Table Panel and you can show all the fields
