Grafana 7.3.4 Logs Panel not working with Elasticsearch
Issue: Grafana 7.3.4 Logs Panel not working with Elasticsearch
Elasticsearch: 7.0+
With Raw Data
Only shows 1
With Logs
Did you configure Logs configuration in the ES datasource settings properly?
Thank you @jangaraj!
Its weird that without making any changes i was able to get the logs by Organising fields under Transformation.
But yes with ES datasource settings it worked.
