I am using grafana v8.3.3 and created a datasource connection to elasticsearch version8 which is on an aws server.
the elasticsearch contains ESB data and logs are passed to it through filebeat. Kibana shows the logs properly from the same elasticsearch datasource. However, when I try to visualize same data on Grafana nothing shows up.
Here is the raw Data which says data is missing a number field on grafana:
while on Kibana I see logs:
Does someone know how I can get the same logs on Grafana as they are on Kibana?
Thank you,
Mehrnaz
