9.4.1 (Docker image) -
Prepare meaningful dashboard from logs stored in elasticsearch -
Using Log panel UI component -
What happened?
I’m unable to show fields by default -
Possibility to define which fields will be displayed by default
I’m trying to replace kibana by grafana for exploring logs that are stored in Elasticsearch (Opensearch actually).
In Explore tab I’m able to go through logs quite easily it works nicely. But I won’t to create dashboard which will be used by some “not so skilled users” and here I have found a problem, I’m unable define which fields will be visible by default in the dashboard so the output is… not very nice. Is there some posibility how to define that for a dashboard / Log panel?
Thanks
