Grafana 6 explore logs from elasticsearch
The new Explore dashboard is really nice to work with logs. I tried it with loki. But I’m wondering if it is posible also to display and search the way it can be done with loki but with a datasource from elasticsearch. Is it posible? If not, any good example to display logs in grafana and be able to filter text?
Thanks in advance
Please refer to https://github.com/grafana/grafana/issues/15999 for log support in explore using ES. For now use the table panel.
