Ive install Grafana via docker in proxmox.
I opened up a browser and went to the URL, after logging in with the default ‘admin’ ‘admin’, I was asked to change password.
I entered a secure password and from then on I get the front page saying ‘Loading…’, after a while, it stops loading and display the error.
Loading chunk 1 failed.
(timeout: http://192.168.1.153:3000/public/build/default~DashboardPage~NgAlertingPage~sandbox.854a662a71a515996d8d.js)
http://192.168.1.153:3000/public/build/runtime.854a662a71a515996d8d.js:1:2645
r@http://192.168.1.153:3000/public/build/app.854a662a71a515996d8d.js:2:3177522
http://192.168.1.153:3000/public/build/vendors~app.854a662a71a515996d8d.js:2:2159549
x@http://192.168.1.153:3000/public/build/angular~app.854a662a71a515996d8d.js:2:1800
w@http://192.168.1.153:3000/public/build/vendors~app.854a662a71a515996d8d.js:2:2159495
http://192.168.1.153:3000/public/build/angular~app.854a662a71a515996d8d.js:2:95663
http://192.168.1.153:3000/public/build/angular~app.854a662a71a515996d8d.js:2:95800
$digest@http://192.168.1.153:3000/public/build/angular~app.854a662a71a515996d8d.js:2:100969
$apply@http://192.168.1.153:3000/public/build/angular~app.854a662a71a515996d8d.js:2:103155
http://192.168.1.153:3000/public/build/angular~app.854a662a71a515996d8d.js:2:10531
i@http://192.168.1.153:3000/public/build/angular~app.854a662a71a515996d8d.js:2:10452
value@http://192.168.1.153:3000/public/build/app.854a662a71a515996d8d.js:2:3293711
zl43@http://192.168.1.153:3000/public/build/app.854a662a71a515996d8d.js:2:3296997
i@http://192.168.1.153:3000/public/build/runtime.854a662a71a515996d8d.js:1:565
a@http://192.168.1.153:3000/public/build/runtime.854a662a71a515996d8d.js:1:431
t@http://192.168.1.153:3000/public/build/runtime.854a662a71a515996d8d.js:1:294
global code@http://192.168.1.153:3000/public/build/vendors~app.854a662a71a515996d8d.js:2:51
Can someone help as Im not sure where to go from here. Thank you.
I have tried rebooting and I’m running the latest Grafana and docker on Debian
