If you’re seeing this Grafana has failed to load its application files
This could be caused by your reverse proxy settings.
If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath
If you have a local dev build make sure you build frontend using: npm run dev, npm run watch, or npm run build
Sometimes restarting grafana-server can help
I used it well with the Docker.
When I restarted, the following message appeared.
