Hello guys
So I’ve installed Grafana on my server.
After that, I’ve changed my configs to this since I want to access it via https://equalizerbot.xyz/status
Also I’ve added this to my Nginx configs:
When I go to https://equalizerbot.xyz/status I get this error:
If you’re seeing this Grafana has failed to load its application files
This could be caused by your reverse proxy settings.
If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath
If you have a local dev build make sure you build frontend using: npm run dev, npm run watch, or npm run build
Sometimes restarting grafana-server can help
Can someone please help me, since I don’t know what am I doing wrong!
