Failed to load it's application files - Grafana Cloud Down?
Hi!
Getting this message (below) when trying to load our Grafana Cloud Dashboard. Never saw it before. Tried multiple machines, browsers, ISPs. None of the part of the check list appears to relate to Grafana Cloud. Please help?
f you’re seeing this Grafana has failed to load its application files
  1. This could be caused by your reverse proxy settings.
  2. If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath. If not using a reverse proxy make sure to set serve_from_sub_path to true.
  3. If you have a local dev build make sure you build frontend using: yarn start, yarn start:hot, or yarn build
  4. Sometimes restarting grafana-server can help
  5. Check if you are using a non-supported browser. For more information, refer to the list of [supported browsers]
Just received the partial outage notification - thanks!
