List of environment variables
If Grafana is open-source, then where is the list of environment variables?
GitHub repo
I tried searching the entire repo and org for a single environment variable (e.g. GF_SERVER_DOMAIN), but it never appears in the source code. Is this closed-source?
That list of env variables doesn’t exist in the source code, because source code tries to map env variable into config option.
E. g.
GF_SERVER_DOMAIN=x
is mapped into config option:
[server]
domain = x
So check default config and you will know which env variables you can use:
Thank you, @jangaraj
But do you know where is the code that transforms GF_SERVER_DOMAIN into [server] domain?
No, there is no name of any env variable hardcoded.
It is just clever code - e.g. read default config and then try to find for each config option if there is env variable for that - if it is there, then override default value:
Thanks so much, @jangaraj !
