Legend Customisation - Azure Data Explorer
    Grafana-enterprise-8.5.2.windows-amd64
    I am trying to convert the Legends to a proper format.
    I want to do that either inside the query. (I am using Azure Data Explorer, which needs queries in KQL).
OR, from Value Mapping or from Override options in the visual pannel.
  • What happened?
    I couln’t figure out how to do that.
I want to convert
“ValueAsReal {Meta1=“Clear Water”, Meta2=“CWT1 In pH”, Meta3=“AIT1879”, Metadata_Units=“pH”}”
to
Meta 3 = Meta3=“AIT1879”
Nope
I tried Value Mapping but It is not working. I tried to use the Regex option, but I couldn’t do anything.
You can achieve this with the “Rename by regex” transform, using something like:
Match: .*Meta3=(.*?),.*
Replace: Meta3=$1
regex_ex
thank you so much. It solved the issue. :slight_smile:
