Good Day,
I am having trouble displaying data from thingspeak via the JSON API datasource plugin.
I am using the following URL to get a the data as JSON from thingspeak:
https://api.thingspeak.com/channels/1103934/fields/1.json?days=7
As query I use the JSON paths
“$.feeds[].field1" and
"$.feeds[ ].created_at”
successfully generating a table.
Unfortunately I do not manage to display the imported data as graph. I suspect they are not recognized as time series.
Help is very much appreciated!
I’m having a similar problem. did you ever get a solution?
Same problem here, had to apply transformation and override unit to get it into datetime format though.
Is that the problem?
patz
December 17, 2020, 12:03pm
4
I am completely new to grafana and I have the same problem.
Can you please tell me how to apply this transformation?
Thanks in advance.
My problem was because the numeric values had quotes around them.
I removed the quotes and it worked
patz
December 19, 2020, 9:30am
6
Thanks for help.
I used the infinity plugin , in basic mode and it worked just fine.
It turned out that this was my problem too. The values with quotes were interpreted as string. I solved it for now by recompiling the plugin on a raspberry pi with less strict value type checks.
With the recent version of json api, you will have ability to specify fields as time fields.
BTW, as @patz said here is a working example from grafana infinity datasource for the url @gregorschulte shared.
Detailed example is available here
Thank you very much it does work for me now, but I have one problem, the maximum return is 100 raws and I have about 1200 rows; How possible to make Json API return more than 100?
