Hello everybody,
Please I need some help in graphing data from thingspeak channel to grafana, I have tried JSON API data source but I got max 100 returns only. Is there any other way to increase the returns of JSON API? Thank you
Hello everybody,
I am using infinity datasource to visualise the ThingSpeak data. See if the example here helps.
The key to your question is you to need to pass the grafana’s timestamp in your url. Without any additional config, I am able to get 8000 rows as shown in the below pic
Thank you very much. Yes, it is so helpful. it does work at my local grafana as I could import the zip plugin, but I couldn’t find this plugin to install it on the cloud grafana dashboard (online).
