Grafana version: Not confirmed as of yet
OS: Linux: Red Hat Enterprise Linux release 8.10 (Ootpa)
Problem:
POMQL queries work fine and produce result set but the results are NOT displaying on dashboards. There are no errors found with any of the POMQL queries.
Details:
Prometheus:
Example of one of the queries for :Average Time Taken (Load → Curate)
SPINS QUERY
====================================== GRAFANA SPINS POMQL QUERY
( ((sum(increase(eis_loader_normalization_duration_seconds_sum{environment=“$environment”, source=“Spins”}[$interval])) / (sum(increase(eis_loader_normalization_duration_seconds_count{environment=“$environment”, source=“Spins”}[$interval]))>0)) or on() vector(0)) + ((sum(increase(eis_canonical_process_duration_seconds_sum{environment=“$environment”, source=“Spins”}[$interval])) / (sum(increase(eis_canonical_process_duration_seconds_count{environment=“$environment”, source=“Spins”}[$interval]))>0)) or on() vector(0)) + ((sum(increase(eis_neo_product_creation_duration_seconds_sum{environment=“$environment”, source=“Spins”}[$interval])) / (sum(increase(eis_neo_product_creation_duration_seconds_count{environment=“$environment”, source=“Spins”}[$interval]))>0)) or on() vector(0)) + ((sum(increase(eis_neo_product_curation_duration_seconds_sum{environment=“$environment”, source=“Spins”}[$interval])) / (sum(increase(eis_neo_product_curation_duration_seconds_count{environment=“$environment”, source=“Spins”}[$interval]))>0)) or on() vector(0)) ) OR on() vector(0)
POMQL CHECK RESULTS:
Note the query above are
What are you trying to achieve? Get POMQL results to display on dashboards.
How are you trying to achieve it? Running POMQL queries
What happened?: POMQL produces results but won’t display on dashboards.
What did you expect to happen?: to get both POMQL results and the same results displayed on dashboard.
Can you copy/paste the configuration(s) that you are having problems with? Done above..
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. None that I have seen.
Did you follow any online instructions? If so, what is the URL? - No but this board originally worked using PCF platform and we migrated it to GRAFAN with Kurbenetes and PROMETHEUS .
