Issues with Image Rendering plugin
Grafana Image Renderer Issue
    Grafana Version 12.1.1 on Ubuntu 24.04.3 server
    To be able to get pdf documents with images of the grafana panels I have created
    By using Grafana Image Renderer Version 4.1.5 to render images and Grafana Reporter to create the pdfs in a report structure.
  • What happened?
    I am unable to render the images and get this as a result:
    To get a pdf file with images of the panels in the dashboard
    This is what i got as an error in the logs:
    logger=rendering t=2025-11-04T08:08:03.713196133Z level=warn msg=“Could not render image, no image renderer found/installed. For image rendering support please install the grafana-image-renderer plugin. Read more at https://grafana.com/docs/grafana/latest/administration/image_rendering/”
    (I saw on github that there were a couple of closed issues where the problem was that the grafana-image-renderer folder was not owned by grafana, but instead by root. However, that is not the case here)
    I installed the grafana image renderer plugin with the command
    → grafana-cli plugins install grafana-image-renderer
    And i installed the grafana reporter plugin with the help of this video:
    https://www.youtube.com/watch?v=qLfJeoJ9ZUA
