Grafana image-renderer-plugin gives error "Failed to render panel image"
I am using grafana version 11.5.0
I tried running the image renderer plugin using docker. Used command below:
docker run -d
–name=grafana-image-renderer
-p 8081:8081
grafana/grafana-image-renderer:latest
Modified grafana.ini such that:
[rendering]
server_url = http://<server_ip>:8081/render
callback_url = http://<server_ip>:3000/
rendering_mode = remote
Seeing that image rendering fails with error message: “Failed to render image”. Don’t see any error messages in grafana.log or docker logs. Able to curl server_ip:8081.
you can follow those official document to resolve your isssue
