We had this setup in Grafana v10.2.5 (ef29c15342) and it was working…
Grafana v11.2.0 (2a88694fd3) -
Allow Viewers access to Explore Dashboard Panels. -
Setting viewers_can_edit = true -
What happened?
Viewers are reporting they can no longer Explore since updating. -
Viewers can Explore a dashboard panel. -
