Not able to Edit Expression in Grafana Dashboard paneld
I have recently upgraded grafana from 6.7 to 9.3.6 When i try to create a expression in a new dashboard panel, it is not showing operations and expression options to add. Can anyone please help me in resolving the issue. I have attached the screenshot for your reference
Thanks
Ramani
I am facing the same here. I thought if I create new ones I would be ok, but is not working.
Same problem here, same solution.
I use grafana cloud there is a way to revert it?
Thanks for opening this post.
This seems to be a known issue as previously reported here:
Please check it and let us know if that helps you to find the answers to you need.
Thanks
