Why the expression option disappear?
Hi all, sorry to bother you. I have created stat panel for my servers in Grafana, The panel has 2 queries (Metrics). And I used “expression” to add the result together.
This morning I found that the expression option disappeared, but the result was not affected. Anyone know how to solve this issue?
Thank you very much!
I reverted back to the grafana/grafana:9.3.4 image and expressions are visible/editable again.
Hi Johnackelley, thank you so much for the help. It solved the problem!!! Thank you again.
